Results 1 to 8 of 8
    Established Member Two Rings Andrewiffic's Avatar
    Nov 25 2015
    AB, Canada
    Touch Up Paint not sticking to car
    So I recently picked up this 2008 Black A4 and it has a few paintchips on it. Some are about the size of a dime. One on the driver's door and a couple on the pass. side. I used a paint touch-up bottle with a brush like I have many times in the past, but the paint didn't stay on after a day of driving. Bare metal is showing, so I lightly sanded the spot (maybe I need to sand it more?), applied the touch up paint till no metal was visible at all and allowed it to dry for at least 24hrs. Then after checking it a couple days later it was gone as if I never did anything.
    I think I read somewhere that Audi uses galvanized or zinc-coated steel for their bodies. Is that why the paint isn't adhering? Do I need to sand it more, prime it first? Or both? I don't like leaving these bare metal chips because I'm worried about it rusting.
    B7 S4 6MT | JHM Tune
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Prime first then touch up. Ideally you'd want to be sanding down, spray priming and spray painting rather than using a touch up kit.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 02 2006
    Wadsworth,OH
    Unfortunately a paint flake the size of a dime isn't going to be able to be touched up with a small brush kit. Likely need to prep, prime, paint/blend/clear a small area.
    Jason
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Quote Originally Posted by Andrewiffic View Post
    I just used Dr Color chip on the jetta and its held up just fine. Where did you get your paint from?
    Feb 24 2004
    Minneapolis
    Maybe a dumb question, but you do this in a warm garage didn't you?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 25 2015
    AB, Canada
    Quote Originally Posted by Guitarmageddon View Post
    I bought it from Canadian Tire. It's worked on my previous cars without issue.
    Quote Originally Posted by mtroxel View Post
    Yup, warm garage.
    I guess I'll have to try sanding it down, priming, then painting. I'm just worried about causing rust because it's exposed right now and not rusting at all so Audi must have some sort of coating on the metal.
    Feb 24 2004
    Minneapolis
    They're galvanized. Rust is not impossible, but a little scratch is much less likely to rust.
    Mar 08 2011
    union, nj
    Well if its zinc and has been exposed for too long, zinc oxidizes creating white rust which is a contaminant. Sanding will remove it but after sanding, wipe it with some thinner to remove dust, and oils. If you went to bare metal re-apply primer, if still has primer then just touch up. Keep an eye on the surface temp and air temperature follow material instructions for applications, and also add clear.
    Hope this helps you...
