I've got a car here that's a good customer of mine, and this one is stumping me. I haven't done a lot of the 09+ Audis, so this set up is still a bit unfamilliaf for me. It's tripping 24 codes, and as soon as you clear them they immediately return. I've checked the harness over for connections, shorts, chafes, things of that nature. The car runs, but it runs rough. Any pointers on things to check, or a step in the right direction would be greatly appreciated. I've heard about the active mounts this may be using, but I'm still researching them.
Here is my ECU scan out:
Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0007
Revision: ECH09---
Coding: 5A2A0013242600062000
Shop #: WSC 49467 000 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 35611FF394992996B5-8060
24 Faults Found:
11914 - Cold Start Valve
P303F 00 [175] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:12
14348 - Left Engine Mount Solenoid Valve (N144)
P1572 00 [047] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153745 km
Date: 2016.02.01
Time: 18:45:49
14347 - Right Engine Mount Solenoid Valve (N145)
P1576 00 [047] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153745 km
Date: 2016.02.01
Time: 18:45:49
18062 - Coolant Pump 2
P261A 00 [047] - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153745 km
Date: 2016.02.01
Time: 18:52:42
4481 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
9490 - Oil Pressure Regulation Valve
P165F 00 [047] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:42
18065 - Coolant Pump 2
P261C 00 [032] - Short to GND
Freeze Frame:
7206 - Cam Adjustment Actuator A; Cylinder 1
P11A1 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7209 - Cam Adjustment Actuator B; Cylinder 1
P11A3 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7218 - Cam Adjustment Actuator A; Cylinder 3
P11A9 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7221 - Cam Adjustment Actuator B; Cylinder 3
P11AB 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7224 - Cam Adjustment Actuator A; Cylinder 4
P11AD 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7227 - Cam Adjustment Actuator B; Cylinder 4
P11AF 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7212 - Cam Adjustment Actuator A; Cylinder 2
P11A5 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
7215 - Cam Adjustment Actuator B; Cylinder 2
P11A7 00 [047] - Elec. Malf. or Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
2798 - Bank 1 Camshaft A (Intake) Position Actuator
P2088 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
12617 - Sensor for Fuel Composition / Quality (G446)
P0179 00 [175] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:18
2972 - Intake Manifold Flap; Bank 1
P2009 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
2984 - Solenoid Valve for Boost Pressure Control (N75)
P0245 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
10530 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Freeze Frame:
4219 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Freeze Frame:
4235 - Evap System Purge Control Valve (N80)
P0458 00 [175] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
4269 - Turbocharger Bypass Valve Control Circuit
P0034 00 [047] - Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 153672 km
Date: 2016.02.01
Time: 17:52:13
Readiness: 0000 0000
