Results 1 to 12 of 12
    Feb 02 2016
    UK
    Does this part need recoding?
    Hi folks,
    Had an issue with hazard lights constantly staying on, and draining the battery. Took my A4 to as garage, where they mentioned they has spoken to VAG that it was the Central Electric Control Module that was at fault (Part No. 8E0907279E)
    I purchased a 2nd from Ebay (with the exact Part No. As I know they can change the Letter at the end on some). http://www.ebay.co.uk/itm/1819936639...%3AMEBIDX%3AIT
    The garage mentioned that this part would need re-coding once fitted? Is this the case? Someone else said it is plug & play. A little in the dark, and would appreciate some advice.
    Many thanks
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The CCM will need to be coded, and its quite simple but requires VagCom.
    http://wiki.ross-tech.com/wiki/index..._System#Coding
    http://www.audizine.com/forum/showth...-Replacing-CCM
    Depending on what the shop is going to charge, you may be better off getting your own cable and DIY. Installing the module is quite simple as well.
    2019 SQ5 Prestige
    Feb 02 2016
    UK
    Cheers. First link doesn't work?
    Feb 02 2016
    UK
    Shop was talking around £80-100 to recode
    Aug 26 2005
    The new CECM only needs recoding if the current coding is different than the original CECM coding.
    Vorsprung durch Technik
    Feb 02 2016
    UK
    How would I know if the coding is different?
    Feb 02 2016
    UK
    Apr 01 2007
    houston texas
    Quote Originally Posted by marcopolo40 View Post
    The link works for me.
    To view the coding you will need VagCom.
    2019 SQ5 Prestige
    Feb 02 2016
    UK
    What's the cheapest way to do this? Cheaper than the shop may charge?
    Feb 02 2016
    UK
    Can anyone throw in some advice on reasonable priced software and cables?
    Feb 02 2016
    UK
    Plugged in the part, and all lights seem to be working, hazards working as they should, car turns over. Is there anything else I need to check or is it all good? I'm guessing the part would just be playing dead if it needed recoding?
    Apr 07 2011
    If everything is working, one would assume the coding is correct.
