Results 1 to 7 of 7
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    What coilovers should I buy
    Do I guys have any input about what coils I should buy I don't wanna break the bank or go cheep I want a nice tight ride . I daily this car and go to the track I already have h&r ultra performance ones But I feel I need adjustable dampening
    May 09 2012
    Virginia
    Adjustable dampening generally puts you in a higher price range. Wanting something you can track and get the performance you need also puts you in a higher price range. You are going to get a bunch of responses here. Typically include PSS9, KW V3 and of course Ohlins. None of which are particularly cheap. Consider other suspension components that will improve handling as well. Sway bars, end links, tires, etc.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Like jbain2 says, you're going to get varied opinions since coils are very subjective. The H&Rs you currently run, is a good, solid setup but agreed, leaves just a tad to be desired when pushed to the limit on the track. Between quality and cost, I believe the PSS series, bar none, are the best you can buy. They are German made and ROCK solid. Having the adjustability in rebound/dampening helps out if you need to go stiffer or softer. Keep in mind though, when at the track, going stiffer does not always equate to better handling. A well matched coilover setup for your car should keep ALL four corners glued to the track when you're pushing it. Sure, some people say one wheel off the ground looks cool, but it does nothing for handling.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    hockey pucks
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I believe you mean *which* coilovers you'd like to purchase.
    Carry on.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Give us a price range to work with. "Breaking the bank" is vague and shouldn't be used when talking about suspension components.
    Oct 02 2006
    Wadsworth,OH
    We have a pretty wide selection of coilover offerings. Post up your budget and I'll be happy to make some recommendations.
    Jason
