Results 1 to 40 of 64
    Dec 12 2014
    Tucson, AZ
    B7 A4 purchase questions
    Looking at a couple B7's to purchase. One being a 2005 and the other a 2006. My question is when did Audi update the cam and cam follower to the revised version? what years? Should I stay away from a early model B7, or is it nothing to worry about as long as the follower was replaced consistently... thanks!
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    As long as it has been replaced accordingly you should be all set...
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Dec 12 2014
    Tucson, AZ
    Quote Originally Posted by Hugh@EuropaParts View Post
    Thanks! I heard the cam lobes in the early cars were prone to issues so I just wanted some reassurance.
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by rborane24 View Post
    Early B7 with the BPG engines didnt have the revised camshaft but they had crown pistons which are forged and from my observation, rarely consume oil. The revised camshaft is 200$ and will take about 3 hours to swap.
    *****I sell in USD*****
    Oct 23 2015
    Australia
    My car,built Dec 20016,uses minimal oil between changes ie <1 quart per my 5000 mile oil changes.I changed the cam follower at 80K even though it was in serviceable condition.Cam lobe perfect.This is a BWE motor,prob similar to the BPG mentioned but is for Australian market and others.
    Its probably asking a bit much for a pre-purchase inspection but if the HPFP is pulled off, the follower and cam lobe could be inspected-maybe at your cost and if its bad,reject the car at no cost to you ?
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Oct 23 2015
    Australia
    Quote Originally Posted by Axis View Post
    Interesting,so Axis that implies the later motors didn't have forged pistons ? Mine is early and uses little oil.Makes sense.
    Feb 16 2015
    Not all the early B7s had the Rev A camshaft. I have a 2005.5 (Jan 31st 2005 build date) with the Rev B cam.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    [QUOTE=rborane24;11373108]Looking at a couple B7's to purchase. One being a 2005 and the other a 2006. My question is when did Audi update the cam and cam follower to the revised version? what years? Should I stay away from a early model B7, or is it nothing to worry about as long as the follower was replaced consistently... thanks![/QUOTE
    I also have the BWE engine on an 2005.5 A4, I did replace my cam follower at about 104000 from what I believe was the stock one and it was in near perfect shape.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Good luck finding your B7! My only advice is to find a Avant. ok.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Oct 23 2015
    Australia
    Quote Originally Posted by gonemtbiking View Post
    How can you tell Rev A from Rev B camshaft ?
    Feb 16 2015
    Quote Originally Posted by Ringsby4 View Post
    You have to remove the vacuum booster pump on the back of the engine, 4 torx screws I believe (pays to have a very stubby tool to get back there). Once you remove the screws and disconnect the hose on the drivers side it will pop right off. Then you can use a mirror or camera to take a look at the cam. 1 Piece is Rev A, 2 piece is Rev B. Here is a pic of my rev B
    Feb 16 2015
    Here are the two cams next to each other.
    Jun 27 2011
    yours was replaced then. The revised cam wasn't factory installed in B7s until midway through the 2007 model year.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 16 2015
    There are a lot of people on this thread with 05/06 build dates with rev B cams.
    I would highly doubt that mine was replaced without me knowing about it, the previous owner kept every receipt he ever spend on the car from the window tints at 30 miles, every oil change, tranny replacement, windshield wipers, but no mention of cam shaft replacement.
    Oct 23 2015
    Australia
    Great info,thank you.I think when you say, 2 piece,you are referring to the disk/plate that sits in what looks like a rebate for Rev 2,whereas Rev 1 doesn't have that disk ,Yes ?
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    i have an early 06 and the dealership replaced it back in 09 as a recall when i took it in for yearly maintenance but anyways good luck!
    Feb 16 2015
    Correct, rev B is actually 2 pieces. In the picture side by side rev B is on the right. If you are unsure, just take a picture of it and post in on here.
    Oct 23 2015
    Australia
    Appreciated again GMB,I'm sure I will be okay with the identification I have just never poked into that rear end of the engine-maybe thankfully ! In about 3 months I intend pulling intake off and soda blasting carbon off,installing new upgrade fuel pump and regulator valve( sitting patiently in parts locker),new thermostat and coolant flange at the aforesaid rear end,maybe that's my chance for a quick look while everything's off.Its my wife's daily but we will pull it off the road for a week to do this and maybe more....
    Nov 15 2011
    Qft.
    Oct 23 2015
    Australia
    Good Luck,sorry,threads are easy to get derailed but I sincerely hope you get an A4 B7.One amazing car,The best looking body,an awesome powerlplant and a whole lot of help here.
    And a word of advice,yes maybe Avant ( style thing IMO ),BUT defin. Quattro and preferably Manual 6 speed,a joy of a gearbox and can control the Quattro drive perfectly,anything else is a compromise...
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    My BPG consumed absolutely no oil at all between 7500 mile oil changes.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by audihere06 View Post
    Ditto.
    My respray thread
    Oct 23 2015
    Australia
    Some B7's don't,do you have a catch can ?
    Every oil change I mop up about 250ml from my upstream SMIC ( your US passenger side ) and some of the rest of my useage ends up all the way to the intake valves and into the CC,its a fact of the crappy OEM PCV system designed to conform with various regulated emissions standards.If mine is getting past the rings or down this route,I wouldn't know...
    Mar 24 2013
    Oakdale, CT
    Same here. I fucked that all up when I built the engine and changed to JE pistons though. New engine is back to BPG slugs, although they have been milled down.
    -Adam
    Oct 23 2015
    Australia
    Quote Originally Posted by Okedokey View Post
    Ditto.
    Hi mate,you too ? Interesting.Most cars I have owned ( lots ) used virtually no oil between changes,save for the few S$#t heaps I drove when younger...
    I'm not complaining about my minimal oil useage but when I pull the intake man.off,part of the explanation will be obvious.
    Nov 11 2013
    Charlotte NC
    Yes i have an 034 catch can but there's usually nothing in it but water. And my valves when cleaned were very clean anyway. No gunky looking wet carbon like a lot of pictures show, just hard dry carbon. Even with an oil leak i had no change on the dipstick.
    Oct 23 2015
    Australia
    I really would like to rid myself of that PCV system,but never have get a clear direction from AZ,ppl are really polarized for whats best leaving the reader confused-there have been threads and threads....
    Nov 11 2013
    Charlotte NC
    I built mine with IE rods and mahle coated race bearings, left the oem forged pistons and put new rings and a fresh hone on the cylinder walls. No oil consumption except when my turbo took a shit the other day. But its all fixed now and breaking in the new turbo with a 400-500 mile conventional oil. Then ill dump it and go back to synthetic.
    Oct 23 2015
    Australia
    Gee,whats your mileage ?
    Oct 23 2015
    Australia
    Okay,so what was the mileage before
    Oct 23 2015
    Australia
    Sounds good ( except for Turbo ) was build for performance or needed to ( motor screwed ) ?
    Nov 11 2013
    Charlotte NC
    It's really not complicated how the pcv works. Basically with the stock pcv you have the inlet to the valve cover from the crank case, which is "filtered" through the stock oil air separators in the head and sent to two places. One side is pulled by vacuum through the check valve into the intake manifold. (This only works when there is a vacuum in the intake.) The other outlet goes to the other side of the valve cover into the cold side of the turbo. What the catch can block off does is remove the line that goes to the intake manifold deleting the check valve and filtering the blow by. Thats the simplest way i can put it.
    Nov 11 2013
    Charlotte NC
    Eh both sorta. It was all stock other than supporting mods and last February while cruising down the highway, the red oil pressure light of death came on. Balance shafts seizure out of nowhere. So i took the engine to a "friend" of my dads who runs a machine shop, went ahead and bought the 06A oil pump and IE rods and let him put them in. Long story short he put the wrong bearings in it and it blew up after 2 hours of run time. So I bought a new block, went back to stock oil pump and put the rods in it and called it a day. I was at 90k.
    Oct 23 2015
    Australia
    Oh,thats no good ,what mileage were you at when you lost oil pressure ?
    Nov 11 2013
    Charlotte NC
    90k
    Oct 23 2015
    Australia
    Oh sorry,90
    Oct 23 2015
    Australia
    Yeah,sometimes when everything is going just peachy-shit happens.Particularly with cars,too many moving parts,Ive considered a horse but I suspect they have even more ! ( and go waay too slow )
    Oct 23 2015
    Australia
    Saving is for you guy's,parts are so cheap compared to over here.I sympathize though ,but just saying
    Nov 11 2013
    Charlotte NC
    If anything else happens with this car im afraid it will have to go. Im tempted to go ahead and get rid of it now.
    Oct 23 2015
    Australia
    Yep,I've seen 034's block off,thats a start.....I just bought a new PCV valve setup as mine failed ( not expeno as you know ) but its taking the engine back to square 1.
