Results 1 to 7 of 7
    Veteran Member Four Rings idotavant's Avatar
    Jan 20 2016
    wv
    changed starter without going psycho
    Was very apprehensive about this. Hard to get to yes, but patience and thought won the day (also researching the web). Removed the wheel, inner fender liner, and lower tray, obviously. Taking the passenger motor mount support off was the key to getting the starter out. some say to remove the motor mount too, but I didn't have to. Defo unclip, unbolt and move the plastic shroud/wiring from the alternator out of the way. Trans cooler lines (i think) were in the way but can be flexed enough for clearance if you unhook the bracket securing them to the oil pan. Don't forget to unhook the battery like me (scared the shit out of me; luckily no electrical damage). I did not need to remove the dip stick tube or alternator. No service position. It was tight, but no problem.
    05 Allroad 4.2 ao3 swap; jhm v3 kit
    06 Dakota 4x4 long travel v8 6spd
    03 Tuono 1000
    04 MB c240 4motion wagon (gf’s)
    02 a4 avant 3.0 tip (defunct; part-out or sale)
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Getting that heat shield back in place was the worst for me. My buddy and I still have nightmares.
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Glad my starter still works (knock on wood)
    Apr 07 2011
    I just had to change the cable running from the starter to the battery. That was enough of a pain, don't even wanna think about changing the actual starter!
    Jun 30 2008
    Erie, Pennsylvania
    A lot of stuff breaks on these cars, but starter failure is reasonably rare. Mine has 275k original miles on it. Cranks every time. Probably just jinxed myself. lol
    Apr 07 2011
    Good! I don't want to look at that starter for a long time. Finally just fixed my battery cable so there should gifts under the tree this year.
    Jan 20 2016
    wv
    "Getting that heat shield back in place was the worst for me. My buddy and I still have nightmares."
    I put that back on after i got it past the trans cooler lines but before it was in posish.
    03 Tuono 1000
