Results 1 to 7 of 7
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    2013 Audi S5 Prestige - 6 Speed Manual - $42,000
    Full listing with pictures and details found here:
    http://penvose.net/beaS5t/
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Established Member Two Rings Blue S4's Avatar
    Apr 23 2014
    Northern IL
    Any interest in trading for a 1991 Acura NSX? Stock, under 70k miles, new clutch and flywheel, very clean. My dad is thinking about moving on from the car for something more daily-drivable, and the values are drastically increasing each month. Quick picture below, I can provide full details if interested.
    Oct 15 2013
    Tampa, Florida
    Quote Originally Posted by Blue S4 View Post
    No sir, looking to sell. Thank you for the interest though.
    Oct 15 2013
    Tampa, Florida
    Bump
    Established Member Three Rings SnowWhite44's Avatar
    Jan 15 2016
    2010 Audi S5 4.2
    Las Vegas
    Bump
    Veteran Member Four Rings mtndog's Avatar
    Jan 22 2009
    992 GTS, F90 M5c, G05 X5 M60
    pnw
    Please let me know if you want to part out the grille
    Dec 26 2008
    STL
    Great looking Car!
    So 2013 got new pedals, steering wheel, and idrive select buttons. Is that about it for interior changes? I don't see any other difference from 08-12
