Hello Everyone,
I have a 2014 6spd B8.5 A4 S-Line with 26XXX miles on it . I have been getting brake noises in the mornings now for the past month, consistently. The sound is coming from the front right. My initial thought was that the brake pad has been worn down prematurely and is causing that side to give me the "replacement squeal". What brings up skepticism is the fact that the noise goes away after some driving, but sometimes it comes back . So I am confused as to if this is just the sound the OEM brakes make sometimes. I have not checked the pads yet, but plan on it this weekend . I remember seeing somewhere that somebody had a caliper that was seized so it was causing the opposite side to wear down at a much higher rate. I can say that I do not feel a pull in any direction, the brakes feel fully balanced and planted. I wanted to confront the all powerful Forum first to see if anyone else has run into this issue.
Thanks in advance!
