Results 1 to 11 of 11
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    B8 Brethren! NEED YOUR HELP re; Front Fog Grille!
    I thought I'd come over fr the B8 A4 Community and ask you all here for help.
    I have a '10 B8 A4 'S Line' which means we share a lot of the same body/interior trim.
    That said, I'm looking for a specific Passenger side/Right fog grille. Apparently, the Drivers side grille had an option to remove the back panel, thus 'opening up' the vents to improve air flow:
    Mfr#: 8K087 681D 01c
    The corresponding Passenger side however has a fixed backing. So, it does not have the option to open up the vents as pictured below the vented one:
    I've been told that some B8 S4s have both fog grilles optioned to be able to open up the vents. I've tried looking up the part on GenuineAudiParts.com as well as ask my local Audi dealership with little results.
    Any/all I info regarding this would be most appreciated!
    I don't feel like dropping $400+ for an Osir Design CF fog grille set!
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Well the drivers side vent is open due to there is a radiator behind there in the wheel well for additional cooling for the engine. It was deleted for the face lifts B8.5's
    Jun 05 2015
    Manchester
    Depends on market car is sold in. My B8 S4 DSG had both the vents closed.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    You could dremel it very carefully. sand and paint it flat black if needed afterward. I'm just thinking out loud in case your part is not offered or too expensive. Also, ebay?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    My old 2012 S4 only had the driver side open due to the extra cooling. Passenger side was solid.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by jl87 View Post
    All the B8's that I've seen have the drivers grill open. I know in my 14 the extra radiator was deleted. Maybe with the 12's they deleted it early and thats y you saw one with a blocked drivers side grill.
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I feel you brother! I went ahead and just made my own, because it hurt to look at the OSIR USA ones! lol Oh and my OCD bugged me it not being even. Haha
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Established Member Two Rings BAGGIN's Avatar
    Sep 27 2015
    NSW, Australia
    Quote Originally Posted by stereojorge View Post
    Digging up old content, these look fantastic!
    2009 Audi A4 Avant
    1976 Audi 80 Fox
    1969 VW Beetle
    1967 MG MGB
    Oct 15 2013
    Tampa, Florida
    Quote Originally Posted by BAGGIN View Post
    Thank you!!
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Do you have a "how to" on this mod?
    They look amazing. Much better than stock.
    I did the same on my B7 S4 but it wasn't that difficult...
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Established Member Two Rings Tod's Avatar
    Jan 13 2016
    Nw burbs Chicago
    Nice mod! Grills look great
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2012 Prestige, TI package b8 S4
    Past fun,
    2008 SRT8 Jeep pwr 440 Blown by Vortech
    1996 Eclipse GSX bunch of crap
    1996 Slp SS 383 Blown by Vortech
