Page 3 of 3 FirstFirst 123
Results 81 to 93 of 93
  1. #81
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    Quote Originally Posted by BKN718 View Post
    What did you paint/product that you used to make it looks so good?
    Thanks for the compliment.
    I used VHT Engine Paint and Gloss coat.
    1. Wheel Cleaner
    2. Wire Brush
    3. Wheel cleaner
    4. Wire Brush
    5. Water spray
    6. Brake Cleaner
    7. Wire Brush
    8. Brake Cleaner
    9. Wire Brush
    10. Water spray
    11. 200 grit Sand paper
    12. 70% Alcohol wipe down.
    13. 200 grit sand paper
    14. 70% alcohol wipe down
    15. Air blow dry
    16. Painters tape and newspaper to mask off area
    17. 4 coats color
    18. 2 coats clear
    19. Vinyl.
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
  2. #82
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Quote Originally Posted by HackDevil View Post
    Thanks! I used VHT engine paint elbow grease.
    Looks great I want to hit mine with some maybe yellow pair once infer everything in order.
  3. #83
    Sep 28 2009
    suburb
    that is pimpin but i am so lazy to take off wheels and paint calipers :) i'll find someone to do it for me.
    what is a good caliper color for a white car?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
  4. #84
    Jan 23 2016
    chicago
    Quote Originally Posted by flyfishing View Post
    What color wheels? Can you post a photo of your car?
  5. #85
    Sep 28 2009
    suburb
    oem wheels and glacier metallic
    Audi SQ7
    Audi B8 S5 (gone)
  6. #86
    Jan 23 2016
    chicago
    very nice indeed!
    You can literally go with any color on that combination honestly.
    Just pick a color that matches your personality. Red is sporty and safe. Black or silver is clean and won't really stand out. Yellow is gaining a lot of popularity. Monster Green is for the brave (very aggressive). Blue is another sporty and safe option.
  7. #87
    Feb 01 2009
    Pa
    very nice indeed!
    How long did it take you to do all 4 calipers. And, how long did you wait after you sprayed the caliper to remove the tape and put wheel back on.
  8. #88
    Jan 23 2016
    chicago
    Quote Originally Posted by Sd76 View Post
    I've only done the front two. I'm still debating about doing the rears.
    Once I finished spraying the last clear coat I removed all the tape immediately. I think I waited about 30 minutes before I mounted the wheel on. I don't recommend you drive for at least a few hours because you don't want any brake dust on the caliper while its curing.
  9. #89
    Feb 01 2009
    Pa
    i like it…you have to do the back now! ALL IN!
    once i get my situation organized i might just do mine in yellow… going gunmetal wheels with black a7 yellow caliper? will see i should just do the calipers now while i wait for the wheels to get here and then get the coils on…. then an INTAKE???? you had roc euro and switched it?
  10. #90
    Established Member Two Rings AY6NYC's Avatar
    May 22 2016
    Queens NYC
    Painted my calipers yesterday. I tried breaking up the copper with a bit of carbon. Eh
    Definitely woke up those calipers, good job
  11. #91
    Jan 23 2016
    chicago
    My first go at wrapping my steering wheel with 5D carbon fiber vinyl.
    I'm also in the process of recording a how-to for my ytube channel. Hopefully not a fail
  12. #92
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    That's pretty cool! I've always wondered how the vinyl wraps on tight curves such as the steering wheel. Looking forward to your video!
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
  13. #93
    Jan 23 2016
    chicago
    Quote Originally Posted by Avned View Post
    I tried not to stretch it beyond 30%. The bottom of the wheel is much tougher.
    The flat parts are much easier.
