Results 1 to 40 of 57
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    resurfacing/honing lifter bores
    Have you done it before on this car or heard of it being done?
    Dec 14 2014
    PNW
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Had a feeling they'd be fucked up. Probably easier to get a head from a wrecking yard?
    Sent from my SM-G900I using Tapatalk
    2000 Achat S4
    Dec 10 2013
    Borden, Ontario, Canada
    2.8 heads then swap the valves
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    You will be much better off buying a "new" used head. I literally just got one off eBay for $120 shipped. You'll probably pay more getting that fixed (if its possible), then you would getting a replacement.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, you wont be fixing those. Would cost way more than another head
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 14 2014
    PNW
    Quote Originally Posted by jaychen View Post
    Me too man. Thing is it's probably mostly damaged from trying to get the lifter out
    I'm contemplating getting a set of heads... But my dad and I discussed honing the bore without pulling the head which I don't like because shavings/grit in the head and crankcase etc..
    I know used heads are cheap and I can probably do the job for 1/4 of what a shop would charge.. I'm just starting to lose motivation, it's been sitting for a month already... I'm mainly pissed because I let a buddy help me when removing the cams because I was under the impression that he knew a lot more than me but he wasn't being a delicate as I would expect when working on a cylinder head.. Can't point fingers or play the blame game because I let it happen.
    What to do...
    Jul 23 2012
    Pullman, WA
    Wow, that happened removing it? Time to get a new friend....
    These should slide right out with a magnet. In my case, I just tipped the head upside down and they all fell out.
    - - - Updated - - -
    PS. Your cam journal is hammered too. Time for new head(s).
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Seriously, how did he try to get them out? Try to wedge a screwdriver in there and pry them out?
    What I don't get is if you are capable of honing the bore, how could you not take the lifter out without fucking the head up?
    2000 S4- Working?
    Dec 14 2014
    PNW
    Quote Originally Posted by redline380 View Post
    Exactly. He was using a god damn flat head and hammer. The lifter was mangle and got wedge maybe .25 inch below the bore.. It took a blind hole puller to finally get it out. But the whole time I had though that that might work best. Since there was already a hole in the top of the fucking lifter.
    Other head looks fine, I've read of people pulling the passenger head without pulling the engine, is it even worth it to try? Or should I invest in a cherry picker?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by cjt671 View Post
    Ho-leee sheeet x10000
    I would donkey punch his ass for stupidity.
    Edit- No idea on how to pull the head, I am a 1.8t guy. I would imagine you can take off both heads though. I'm sure I'd waste a good part of a day trying to before realizing I should have asked and then pull the engine anyways
    2000 S4- Working?
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    If you're in the b5 game for the long haul get a picker
    Jul 23 2012
    Pullman, WA
    Definitely pull the engine. I pulled heads off a 2.8 last weekend, and it was a major PITA. I was able to get the passenger side off without to much damage to other components, but the driver side was terrible. The timing belt cover attaches to the block and coolant hard pipe and it is impossible to get to those bolts without at least the core support off.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why not drill a pilot hole and screw a self tapping screw into it an pull it out .
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by AudiTechS4 View Post
    Because it would just spin! lol
    2000 S4- Working?
    Dec 14 2014
    PNW
    I should have told him to stop and asked him to leave.. It's was awkward situation b/c he's higher ranking than me and that plays a role in civilian life if you know what I mean..
    I'm reading old posts about people being able to pull the passenger head without pulling the engine.. I had hoped my first engine pull would be for a new set of turbos to go stage 3..
    You fellas use the cheapo harbor freight picker without issue?
    Dec 14 2014
    PNW
    Quote Originally Posted by Bordom View Post
    2.8 heads would be nice man.. I'm considering it, need to do more research
    Jul 23 2012
    Pullman, WA
    Where are you at in PNW? I have 2 2.7t heads that I dont need.
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Heads can definitely be pulled without removing the engine. I did it a few weeks ago on a 2.8. It's a lengthy job (took a weekend) but nothing terrible.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Jul 07 2015
    This is a shame man! But think of all the experience you are getting :)
    Saw this over on vortex in case you might be interested ... http://forums.vwvortex.com/showthrea...ads-50each-obo
    I'll be curious to see how you end up turning this around.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    No way in hell I would deal with bs of taking heads off in the car.
    I've seen it done, but Id def pull the motor out so you can get to everything and do a better job.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Generally speaking the best way to do any kind of work on the 2.7T is to pull the engine. No B5 S4 owner should be without a cherry picker. Its a necessary tool for owning a 2.7t.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Dec 14 2014
    PNW
    Figured I'd update here but we threw the bitch back together and we'll see how long it last till I really need a new head even though it was yesterday
    [flame suit on]
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Wow, I wouldnt have done that. That lifter bore is fucked
    2000 S4- Working?
    Dec 14 2014
    PNW
    I know. It was hard to do. We took down the high spots and ensured the lifter moved in the same way the other bores do.. Cars running with no issues.. Haven't driven it yet though. I'll post back when it blows up again, I wanna see how long it will be before it eats that cam
    Feb 19 2011
    Earth
    A good attitude to have for short term enjoyment. These cars are old and will break. Fix it when it breaks and dont blink an eye until that point.
    2000 Achat S4
    Jul 23 2012
    Pullman, WA
    Your willing to run that and risk blowing your entire engine rather than just pay $100 for a new head?
    Wow.
    Dec 14 2014
    PNW
    Yeah, I may regret the mentality one day, but for now I'll be young and dumb with a running(till it's not) b5 s4
    Also I bought this as a project car,
    Where I fucked up is selling my A4, I should find a daily, maybe a Honda lol
    Dec 14 2014
    PNW
    Quote Originally Posted by mauromj View Post
    Wow.
    Yes I'm doing a science experiment
    Jul 23 2012
    Pullman, WA
    Subscribed.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Wow.
    The whole engine wont "blow". Absolute worst that could happen is he floats a valve, it breaks, and knocks a hole the that piston, possibly fucking up the bore.
    So, yeah, I guess you could consider that a total engine failure lol
    2000 S4- Working?
    Jul 23 2012
    Pullman, WA
    That is exactly the scenario I had in mind. That's pretty much blowing. AKA, replacing your whole engine rather than just the head.
    PS. I said blowing. hehe
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    The main issue here is the gouge in the bore that even if you cleaned up the high spots, it will act as a larger than stock leak in the oil pressure system. This could cause overall system pressure drop. I guess keep any eye on it and let us know.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Dec 14 2014
    PNW
    Quote Originally Posted by slow ride View Post
    Yeah I'm gonna consider getting an oil pressure gauge if it stays running long enough. Just to see what the exact effect it has is.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Lets not forget about possibility of metal shavings getting into the oiling system.
    I don't know what you don't just replace the head.
    2000 S4- Working?
    Dec 14 2014
    PNW
    I understand all the risks associated with running this head. Let's not forget that this is a 16 year old car, I understand that it's no where near the best option. Best case the cam lasts long enough until I go to training and then transfer to my next unit.. Which is why I need the car in a running state, military will not likely ship a non running car and I'm anticipating leaving soon. I don't want to just replace the head without sourcing a performance set of valve train components and all that jazz. I also think it'd be a waste to pull the motor without throwing a new clutch and turbos in it, I don't have the extra money to do all that right now and even if I chose to spend some money on all that (8-10k) I don't think I would have time to do all that before I leave here.
    Worst case the engine "blows up" and I start from scratch using performance components and have a reason to completely rebuild everything that I see fit
    Nov 05 2009
    Denver
    You guys are silly. The only thing that will happen is the lifter will wear again possibly taking the cam lobe with it. Why do you think the lifter had a hole in it from the get go? It stopped spinning. LOL at losing oil pressure due to a lifter bore
    Apr 20 2005
    New Hartford, IA
    What funny is that you laugh about it not that I said it :) I didn't say all pressure, but it is a larger leak. which is all the oiling system is a controlled leak. Open up bearing clearance and pressure goes down with the same fixed displacement pump. He never stated the original reason for all this work unless I missed it.
    02' Tundra
    Dec 14 2014
    PNW
    Quote Originally Posted by Zba View Post
    That's my hope.. Which is why we took down all the high spots to ensure free movement of the lifter, rotated the engine a bunch and check movement to the other bores.. Driven 15 miles so far.. Haven't gone into boost much though..
    I've read up a bunch about lifter failure and a lot of people point the finger at diminished amounts of zinc in the oil causing more start up wear.. not sure the whole truth but possible I guess
    No oil pressure warning so far..
    And we got the timing right the first try haha
    Dec 14 2014
    PNW
    Got home and she was chattering like a diesel popped the valve cover and was pleasantly surprised
