Results 1 to 7 of 7
    Dec 19 2014
    Salt Lake City
    Idle woes: "idle control system, RPM higher than expected - sporadic"
    Hey all,
    I'm somewhat new to the B7 and this may be an old issue. I couldn't find a lot of info though....
    '07 B7 6-spd, 106K miles:
    I've had the following code pop up a couple times of late and the car seems to be idling high and not "revving down" between shifts or when the clutch is depressed to come to a stop:
    01287 Idle Control System, RPM higher than expected - Sporadic 001 Upper Limit Exceeded
    The first time I had the code, I had my local shop check it and they did a TB re-align (which I would have done myself had I known that was the treatment they would try). Things were better for a while, but then the sporadic raving started back up and the CEL came back today. Same code.
    Any thoughts on what might actually be causing the strange idling and revving? Do I need to tell my wife it needs software and an exhaust? ; )
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Try cleaning the MAF sensor. Then clean the throttle body plate. And tighten the bolts around the intake manifold they usually come loose which causes vacuum leak.
    Dec 19 2014
    Salt Lake City
    Thanks Kevin! I'm assuming vacum leak as well... The shop claims they checked for that, but I'm a bit skeptical. They supposedly cleaned the MAF too, but I'll give that a shot too.
    Anyone had PCV or other vacuum leak issues I should look for?
    Jan 10 2016
    Springfield Ma.
    Any good luck with this issue? I'm currently having the same problem it sounds like. Between 1-2 thousand rpm it's stutter stepping. It almost seems as if the car is possessed, like it doesn't want to cruise or coast it wants the pedal down lol. How do I fix this issue? 05 S4 tip if that helps....I'm sure this can't be good in the long run. And it's embarrassing.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Verify the MAF hose is fully seated and secured onto the throttle body. Even a little gap can throw to logerythmic computer off big time.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Jan 10 2016
    Springfield Ma.
    Yes. It's seated completely. Bad MAF you think? It runs fine if I'm in higher rpms just between1-2 rpms it's stuttering. I changed spark plugs and filter, maybe ignition coils would cause this?
    Jan 10 2016
    Springfield Ma.
    I'm drawing blanks on what this could be. Is this how the timing chain issue starts off then end up progressing to being the apocalypse under the hood?
