Results 1 to 12 of 12
    Veteran Member Four Rings ChicagosPhantom's Avatar
    Aug 28 2013
    02 Nemo S6 (stolen) / 03 Silver A6 2.7T K04 01E / 03 Daytona RS6 / 04 Dolphin A6 2.7T 01E / 02 Silve
    Chicago IL
    Rear sway bar 22822 Hotchkis A6/S6
    Gone!
    Last edited by ChicagosPhantom; 02-11-2016 at 04:35 PM. Reason: No longer available
    Aug 17 2015
    Portland, OR
    Not seeing the price - how much are you asking, shipped to Portland, OR?
    Aug 28 2013
    Chicago IL
    I would like to get $180 for bar plus shipping.
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    They've stopped manufacturing this part; NOS only now from Hotchkis. Grab it while you can!
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Jun 03 2015
    Syracuse, NY
    Does changing end links help with changing stock bar to Hotchkiss bar?
    Aug 04 2009
    Glen Ellyn, IL
    Doesn't fit allroad, Brian.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    thats mr brain to you
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by A Stupid Turtle View Post
    I put new links when I installed Hotchkis bar,I was thinking there's gonna be more damage to stock end links but definitely worth spending 5 more mins replacing old end links.Even changing bushings and end links will help stock bar will give you less roll as factory rubber will rot over time.But Hotchkis is the way to go...really best upgrade,transfers car so much that puts a huge smile on your face every time you turn steering wheel.
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by 4rings2turbos View Post
    Quote Originally Posted by alien_brain View Post
    Beat it you two...hahaha
    Veteran Member Three Rings Chris_s1's Avatar
    Apr 07 2014
    Miami
    Shoot me a text 305-989-5323!
    2000 2.7t 6 Speed Build in Progress...
    Aug 28 2013
    Chicago IL
    Will fit allroad if swapped to static and compressor was deleted.
    Aug 28 2013
    Chicago IL
    Do not contact me with payment options,half money now half in a month and such.I'm in no rush to sell and not asking thousands for it,I'm fair at my price.
    If you guys can't scoop couple Benjamin's for the bar,then you shouldn't be contacting me.
    Thank you gentlemen's and good luck in your search.
