02 Audi S4
Tiptronic
120k
EPL Stage 2 Tune
Vibrant Catback
SSAC 3" Downpipes
710N Diverter Valves
K&N Drop In Air Filter
18x8.5 3SDM 0.06 (tires have little use about 90% tread)
ST Coilovers ( Have them around 24.5" Fender to ground)
Podi Steering Column Boost Gauge
Clear Corner Headlight Mod
Independent Fog Light Mod
M3 rear trunk lip
Oem RS4 Grille
Recent Maintenance:
Timing Belt/Water Pump/Thermostat 3/22/14 - 103,812
Upper/Lower Control Arms Oem /Tie Rod ends done at 112k
Valve cover gaskets 115k
Throttle body boot 118k
Pads&Rotors all around115k
Spark plugs(BKR7E's) & valve cover gaskets done 118k
Brake Fluid flushed 120k
New battery 8/15
The Bad:
Cupra lip is not on the car , broke this past winter by a piece of ice . There is a small hole in the bumper where the lip was . Its on the underside of the bumper & cant be seen unless you look underneath. Windshield has a couple tiny chips , not cracked & are repairable. Still has oem windshld.
Extras:
Stock grille, rear window spoiler, can include stock wheels powdercoated black with new tires , extra front filler plate
Looked at quite a few b5s in search of one of these .That being said , this is a very clean/above average condition car for sure.No surprises with this car . No check engine/abs/or airbag lights on. Cluster is 100% no pixels are out . Looking for 7700$ Clean CT title in hand . Can work out a price with/out wheels etc. Text 203-25two-9three43 o.b.o NO trades .
