Results 1 to 40 of 58
Thread: Audi mmi update
Hybrid View
    Aug 28 2015
    "2015 challenger r/t"
    Audi mmi update
    Has anyone had their mmi updated to the latest software?i have a 2012 a7 never been updated before do anyone know how much this could cost?
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    I just had this done. Is your car under warranty? If so Audi has a TSB that can be completed which replaces some hardware and comes with a software update. I had this completed about two weeks ago. Basically this brings the system up to what the 2015 models have. You just have to complain of the 3G dropping to 2G a lot and/or of your phone dropping its Bluetooth connection frequently. Not sure if Audi does this TSB out of warranty or what it would cost.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Established Member Two Rings Davor_'s Avatar
    Nov 10 2015
    St. Paul
    Quote Originally Posted by RRF985 View Post
    Can you give me more details on this and where can I check tsb's for our cars?
    Thanks.
    Active Member Two Rings cjryan33's Avatar
    May 23 2013
    2010 Chevy Tahoe Z71
    Fulshear, TX
    My 2013 does not even display 3G anymore, just 2G. Do you happen to have the TSB #?
    2013 A6 3.0T Quattro, APR Stg 2, Injen Intake, AWE Touring Exhaust
    Aug 28 2015
    My car is under a 3rd party warranty now.i was quoted $499 which is a little high for just a nav update I can use my iPhone for that.
    Apr 16 2014
    NW Burbs of Chicago
    Think TSB is 2039515/4. You shouldn't need it though. Just call up, make appt, and say that your 3G is now only showing 2G. I did this and got the latest MMI version.
    2013 A6 Prestige
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by wuk View Post
    That's exactly what I did to get mine updated. Thanks for posting the TSB number as well as I could not find it.
    May 23 2013
    Fulshear, TX
    When you get a chance, could you please let me know what version your MMI is running now?
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    My understanding is these changes took effect in MY2014 at which point the MMI hardware is different and properly supports the new AT&T frequencies. So anyone with a 2014 or newer need not try this as you will not get results, and you should have 3G anyway.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Jun 29 2014
    In USA cars they uses different Telit gsm module.
    For example while importing from USA to EU you need to install Telit - UC864-E- AUTO - Cellular Module instead of NAM one
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    I was quoted $562.50 for a MMI update on my 2012 A7.
    Nov 10 2015
    St. Paul
    Just did as instructed above and got mine updated.
    They say mine was in 400s and the latest a firmware is in 800s.
    Sep 05 2012
    Boston
    Quote Originally Posted by Davor_ View Post
    Did they charge you?
    Thanks
    Nov 10 2015
    St. Paul
    Audi mmi update
    Quote Originally Posted by fantaxp7 View Post
    Thanks
    No, I did notice that now I have 2G instead of 3G all the time (but I don't really use the internet so I don't care)
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    I got the latest v.814 on my 2012 A7 but i don't think any hardware was replaced..
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Nov 10 2015
    St. Paul
    Quote Originally Posted by 07S6 View Post
    Same here cause now I actually have a problem 2G all the time
    Apr 12 2014
    Atlanta, GA
    The latest: 814
    Apr 16 2014
    NW Burbs of Chicago
    if you have the 2G problem, they will replace hardware and update to latest version (v814). this should all be covered and free.
    2013 A6 Prestige
    Apr 12 2014
    Atlanta, GA
    A bit more information since I just came across my paperwork from having the updates done. Two TSBs were completed: the first is 2039515/5 which is for the 5F hardware to be replaced and updated and the second is 2030465/7 which updated the MMI to 0814. I hope this helps some out.
    Dec 24 2014
    No. VA
    Thanks for the information. I have a 2012 A6 3.0T as well. I think my MMI version is 0488. Did you notice anything different/better with the with software?
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by quad_drive View Post
    Yes. It now has Google Streetview which I couldn't get to pull up prior and it's easier to get to the Connect stuff in the menu now as there is an Audi Connect selection. Also the download speeds are quicker than before. I also haven't had any issues with my phone since the update.
    May 23 2013
    Fulshear, TX
    I have an appt for Thursday to get mine updated. I mentioned the 2G and bluetooth and he said there was an update for that. Only have 9,000 miles left of warranty and glad to be getting the latest update. Thanks RRF985 for posting about your MMI getting updated.
    Nov 10 2015
    St. Paul
    I was in the 400s as well and after the update I noticed a new source in media and everything is a bit faster and smoother.
    Jun 05 2008
    Carmel, IN, USA
    Having a Windows phone that won't stay connected will get you the update. A TSB tells them to update the OS for this.
    '14 S6 Prestige Phantom Black Pearl Effect/Black: Sport Rear Differential, Head-up Display, Night Vision, Driver Asst Pkg, Contour Seating, LED Headlights, Layered Aluminum/Blk Wood, Sunshades, Cold Weather Pkg, Rear Airbags, Side Tint, Auto Hold, Audi Platinum Protection 12/'21 96,912 mi
    ’13 Mercedes Benz E 550 4Matic
    '16 Honda Odyssey Touring Elite Obsidian Blue Pearl
    Sold: '05 A6 C6 3.2Q Stratos Blue Loaded
    Mar 19 2015
    For anyone who was updated - Did this clear any VAGCOM tweaks you had? Any new functionality? I'm using a T-Mobile sim in my '12 A7 and the 3G coverage in my area is great for online destinations and Google maps. Wondering if it's worth the effort.
    2012 A7 Prestige Moonlight Blue Metallic | Velvet Beige/Dark Carpet | Fine Grain Ash Natural Brown Inlay | Cold Weather Package | Audi Side Assist | Mods: 20% Tint | Viper Smart Start | VAGCOM Coding
    Active Member Two Rings on3eighteen's Avatar
    Jan 15 2016
    NH
    It sounds like there's 2 things that can be changed: 1.) Hardware & 2.) Software. I'm guessing the software update is free *but* the hardware upgrade costs $$$ *unless* you can convince them your hardware is flaky. Sounds like the best way to get new hardware is to specifically say things about the cellular radio working sporadically. Does that sum it up or am I off base?
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by cellphonechris View Post
    None of my VAGCOM mods were changed.
    Quote Originally Posted by on3eighteen View Post
    You are correct. However Audi has published letters to owners stating that they will change the hardware if necessary due to dropping to 2g a lot since T-mobile is updating their towers. I'm not sure if Audi would give the free update for the T-mobile tower change out of warranty though. I figured I'd just mention the dropping to 2g to my dealer since I knew about the letter. They went from there.
    Junior Member Two Rings mchltschr's Avatar
    Aug 28 2015
    Milwaukee, WI
    I'm headed in for my weekly oil change and having them look at my MMI. Bluetooth, since I purchased the car, has always seemed unacceptably slow to me. I am hoping the firmware refresh will provide some smoother connectivity. Has anyone seen an improvement in time to connect bluetooth with their MMI updates?
    Nov 10 2015
    St. Paul
    Quote Originally Posted by mchltschr View Post
    My Bluetooth is worse now than before to be honest.
    Not to mention that now my Spotify control doesn't work as it should (forwarding a song).
    Mar 02 2009
    State of Confusion
    I'm headed in for my weekly oil change and having them look at my MMI. Bluetooth, since I purchased the car, has always seemed unacceptably slow to me. I am hoping the firmwaefresh will provide some smoother connectivity. Has anyone seen an improvement in time to connect bluetooth with their MMI updates?
    Weekly oil change?????
    Aug 28 2015
    Milwaukee, WI
    Quote Originally Posted by mjfloyd1 View Post
    LOL. Results of this workweek frying my brain. Correction: Yearly
    Apr 12 2014
    Atlanta, GA
    Mine is the same after as it was before. My phone connects instantly when the car is started but the transfer wait time is still the same as before.
    Sep 05 2012
    Boston
    Do they charge you for just brining your car in?
    I scheduled an appointment and I only intend to go through with the MMI update should they offer it for free. I hope they don't charge just for the visit.
    I also called and had them be aware of the recall notice I got and they said they'd take care of that at the same time....hopefully they feel kind and do both :).
    Nov 10 2015
    St. Paul
    If the reason for you coming in is a mmi "problem" then they font charge but if you go in just to get an update then they will most likely charge you.
    Mar 19 2015
    I'm heading in on Monday for the PODS recall - Going to see if I can get the update performed in the same visit. Since I'm now on CPO warranty, I may be able to avoid the deductible.
    Nov 10 2015
    St. Paul
    I'm on my cpo (kicked in on THE DAY of going to the dealer) he said it's not covered by cpo but after me talking to him and asking to see if he can do something they did if free of charge.
    So don't give up if they say NO
    Mar 19 2015
    That's interesting - I was under the impression that my CPO warranty carried the same coverage as the factory warranty, with the exception of the deductible (~$80).
    Apr 12 2014
    Atlanta, GA
    If your car is under warranty there will not be a charge as long as you complained about some issue and didn't just tell them to update it.
    Mar 02 2009
    State of Confusion
    CPO does not cover MMI related to navigation or sound system. Audi pure platinum VSC does. You could get a CPO wrap that covers the things that CPO doesnt cover, but the cost of CPO plus CPO wrap is more than the cost of Audi pure platinum VSC
    Apr 12 2014
    Atlanta, GA
    Correct however this is not a navigation nor sound system problem so it could very easily be argued that it should be covered.
