Originally Posted by
Backyard22
Normally when I turn on my car the fog lights will turn as they act as DRL on the B6.
On my car only the driver side foglight is on, Passenger side doesn't seem to work. However, when I turn on the foglights, both on them would turn on.
What do you guys think is the issue here?
Is it consistent or is it on/off issue, but
most of the time they both turn on when you turn on the foglights?
I ask because I had a possessed foglight that I couldn't figure out, changed bulbs etc. It turned out that a pin in the connector was loose and each time I pushed the connector in, it would push out and make only intermittent contact. Once I removed it, bent the retaining pin a bit more to lock it in place in the connector, I've had zero issues.
