Results 1 to 4 of 4
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    Weird Overheating Issue (2.8 V6)
    So Having issues with my car recently as the temperature in the land of kangaroos heats up, general summer temps are 36-45 degrees c (97-113 F) So as you can imagine the cooling of my car is quite important.
    So, driving around the suburbs in normal flowing traffic the car is fine, temp stays dead centre at 90c and oil wanders up a little (1/2 a bar) but no further. When driving in the city in stop start traffic however the temp just rises and rises, till the coolant boils over and the oil gets 1-1/2 bars higher than centre.
    Info about the car, Timing belt, water pump and i assume thermostat done 30k ago, Viscous fan exploded so replaced with EFK which I always have on, motor has been coolant flushed and heat works well and gets up to temp in around 10-15 mins in normal conditions. Only overheats in stop start traffic. This has me thinking either the radiator is blocked or the EFK doesn't give it enough air flow.
    After overheating i refilled with water and turned the EFK and thermo fan on and it stayed at 90c all the way home. I have ordered a new fan clutch and blade to replace the EFK (may install on front of radiator for emergencies) but what do you good people think it may be?
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Sounds like a possible water pump problem to me, do the quick test and take off the line to the expansion tank and hold it over a bottle and have a friend hold it at 2500 rpms and see what kind of flow you get. Could also be a sticking thermostat. I'd guess one or the other.
    Sep 13 2012
    Adelaide, AU
    I will take that method under advisement thank you mate!
    Borrowed my mechanics infrared temp gun today and tested the rad, top was 108c and bottom was 52c, so over 50 degrees difference top to bottom, he believed it was atleast 30% blocked, causing circulation issues and lack of cooling, thoughts?
    Dec 10 2013
    Borden, Ontario, Canada
    Could be blocked, but Thermostat would cause the same thing. Do a flush and see how it helps
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
