Results 1 to 40 of 47
    Established Member Two Rings xwilliams23's Avatar
    Aug 05 2015
    2006 Mazda 6
    Milton
    How much can I get out of k04's?
    Debating on many things with my car right now and the biggest dilemma is the turbos.
    I know going with k04's is the cheapest route. But is it really worth it? How far could I take these turbos.
    What do I need to hit 350, 400, 450+ Hp?
    Would. You guys recommend waiting a bit and getting a different setup? If so what are some other great options?
    Thanks 😊
    Established Member Two Rings JaredB5s4's Avatar
    Jan 12 2016
    Kitchener Ontario Canada
    Well there are the rs6 hybrids that will get you over 500whp
    Ko4s can get you into the 400s
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by JaredB5s4 View Post
    Is the jump worth it?
    Jan 12 2016
    Quote Originally Posted by xwilliams23 View Post
    You have to upgrade more with them so it will be more expensive, it depends on what your goals are.
    Aug 05 2015
    2006 Mazda 6
    Milton
    How much do you think it'd take for k04's to reach those Hp numbers I showed above?
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Did you seriously ask "what can you get out of k04s?" That question has been beat to death so many time it's not even funny. There is so much data on this website alone with every possible scenario describing the power output of said turbos.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by mikeb17 View Post
    Indeed I did,
    Care to share?
    Thanks.
    Oct 27 2012
    Lamborfeetes
    Washington
    Try google, if that's not beyond your capabilities.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Don't know why you're acting like that, But thanks anyway
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Thanks 😊
    K04's are not the cheapest, if you purchase Borg Warner. If you are trying to get a lot of power they aren't a good choice since they are on the small side of the options that you've got. On the other hand if you can settle for around 400 whp they'll be the fastest responding turbo's you can get for the power level, which is a nice thing for a daily driven car.
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Not necessarily, you're going to need pretty similar supporting mods for either k04s or k24s.
    Obviously you'll need a lot more to max out the k24s though, internals, custom fueling, etc
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by FlyboyS4 View Post
    Thanks flyboy. What's the cheapest option btw?
    The car is my daily right now and I know I would be satisfied with 400hp for a while. But in the long run, if I was to look to get more power. Would I most likely have to rid of those and move on? Seems like.
    Veteran Member Three Rings kingkhalilz's Avatar
    Jan 31 2013
    Mchigan
    Dont want to correct you or anything but to clarify k24's on e85 over 500 whp. Dont know anyone to get that on 93. Aysix hit 480 on 93 + meth.
    **I wish i got 500whp
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you are going to drive it on the street, look into frankenturbo f21s.
    I think you give up too much on the bottom for what gains you see on the top with anything larger.
    You can do good things with the big turbos, but bolting them on a stock engine is usually not one of them.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    OEK KO4s, OEM inlets, good intercoolers, good 3 inch DP's and a quality exhaust = a solid 400+whp daily drivable car. This is the way to go.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by zillarob View Post
    Was also another valid option. How would the feel as a daily though?
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by TighTT View Post
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Seriously man, spend the time waiting for responses here to do some research.
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Quote Originally Posted by DieselElectric View Post
    Exactly. Won't take you long to find info. Just a thought. Google is your friend.
    Do you have a budget? K04's on stock fueling and tuned accordingly will allow you to save on supporting mods for the time being.
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Agreed. Everyone forgets how fast all the OG K04 cars were.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    If it helps any I made 400 awhp exactly on 034's old dyno jet at Iroz motorsports here in Las Vegas during mid summer. On a mustang dyno it supposedly yields 7%, so 430ish? I am BW K04's, SRM intercoolers with Daz tuning on a conservative end. I am also on E85, which is what gets you into the 400's. I have a build thread if you need to see the details of my build. Like i said it is pretty basic and the car is a daily and one hell of a reliable car. I'd say I have been pretty lucky.
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by QuinnsterKID View Post
    Thanks that's a really helpful reference. I couldn't find your build thread but I'd like to check it out. But dang. There is no e85 near me
    Jan 12 2016
    Quote Originally Posted by CELison View Post
    ^ true
    Mar 02 2010
    Las Vegas
    Here is my build....
    http://www.audizine.com/forum/showth...mple-and-clean
    Nov 02 2014
    Winchester, VA
    93 + meth can get you a bit further than straight pump. Still doesn't compare to e85 though.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Just read the entire thread.. all I can say is wow!.
    Sent from my SM-G925W8 using Tapatalk
    Jan 06 2007
    Mk7 Golf R
    FL
    Thanks 😊
    What power are you making now?
    Oct 27 2014
    Flag/Phx, AZ
    Love your build.. Ive been using yours as a standard for how clean I want mine haha, almost impossible to match. Huge props for all the hours that went into the cleaning everything
    IG: CJ_s4
    Aug 05 2015
    2006 Mazda 6
    Milton
    My car is currently k03's tuned by daz.. Never dyno'd. Not until I get my build actual going
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    You should try to go to some meets and meet up some fellow B5 S4's in your area. And hopefully, someone there will have a stage 3 you can ride in. And you can decide from there. To bad you don't have an E85 station near your place. Once you feel the difference from 91, 93 and E85. You will see why E85 is so special. The corn juice is just magic I tell you.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by xalents23 View Post
    You should try to go to some meets and meet up some fellow B5 S4's in your area. And hopefully, someone there will have a stage 3 you can ride in. And you can decide from there. To bad you don't have an E85 station near your place. Once you feel the difference from 91, 93 and E85. The corn juice is just magic I tell you.
    Best pump near me is 94.. in my area up here in Canada I hope I can find way more b5 owners. As far as I know theyre aren't many.
    Jan 06 2007
    Mk7 Golf R
    FL
    You're probably around the mid 200's, 250 +/- 10-20 whp.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Yea those are the numbers I've read some of the other guys are making.
    Jan 12 2016
    Come to Berlin klassic, euro United, euro krazy and vag Kraft ..... All car shows in Canada with b5s there.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Thanks. First year with a b5. So I haven't looked into to many meets. Now that summer is coming I'll definitely be at them
    Established Member Two Rings 2000Stg3S4's Avatar
    Jun 03 2015
    canada
    Yes Berlin klassic...we need more b5's
    Sent from my SM-G920W8 using Tapatalk
    Mar 02 2010
    Las Vegas
    Quote Originally Posted by CJ_ View Post
    Thanks guys. It took almost 8 months, but I took my time and made sure everything was perfect. Well worth the headache haha
    Mar 02 2010
    Las Vegas
    I agree with xalents23. The corn is a beautiful thing. During tuning I was initially tuned for 91. It was to get small things sorted out, and empty the tank in order to switch over to E85. On 91 octane I thought the car was a beast....but when the tank went empty and I filled it up with E85, flashed the new tune and hit boost my mind was blown. It almost broke my neck. Crazy suggestion, but why not buy a 55 gallon drum and drive down to somewhere with E and fill it up and store it?
    Aug 05 2015
    2006 Mazda 6
    Milton
    Well mostly because I think for the time being just 94+meth could do the trick. I know once I try the e85 I'll be hooked. And I'll probably be making trips to fill up some Jerrys
    Jan 12 2016
    Quote Originally Posted by 2000Stg3S4 View Post
    Yes there will be a bunch coming this year. I never knew about it last year.
