This is for zokissima and whoever else would like to see how to get to the cam sprockets to view / verifytiing. Here is the timing cover:
It's staring right at you on the front of the motor, once the engine cover is removed and right next to the oil filter. In the picture, I've already removed the 3 bolts and the intake cam sensor. To remove that, just unplug the sensor, the 3 bolts and it falls out in your hand.
The cover has 5 bolts with a few in odd angles. One you have to remove the 2 bolts that hold the oil breather / oil dipstick (as most of us have converted it over to) so you can move the dipstick out of the way and get to that one bolt.
The front core gets in the way of getting to these with a standard T-27 and T-30 bit, so I had the same sizes in the small 1/4" size bits and used a 1/4" ratching open end to get to them. Tricky and the hardest part is to not drop the 1/4" bit LOL. I actually batted 1.00 during this; no drops. The bolts don't come completely out of the cover, they have retainers. Make sure they are completely loosened and extended as far as you believe they can. You'll know if they aren't far enough out when you try to remove the cover and an area is stuck/hung.
Here are the postion of the 5 bolts:
One at side and at the bottom of the passenger side:
One on top on the driver side and the one behind the oil dipstick (I have the bolts out that hold the dipstick in place already; they are T-30's IIRC
And one on the direct bottom:
Once all bolts are completely backed out, the cover slides right off and you can now see this:
To get back on topic, per what I said above on how the chain was jumping; you can see in the pic above that the chain was stuck ON the teeth of the sproket on the exhaust cam sproket (left).
Here's some more pics of what I did today/what I got accomplished:
Front bumper cover/facia and headlights removed:
Removed the aluminum front bumper crash support bar, unbolted the A/C condensing unit and swung it off to the drivers side (like my rig? LOL):
Radiator removed:
Front core frame/support removed:
Full access to the motor now:
