Results 1 to 9 of 9
    Established Member Two Rings Silverrotor's Avatar
    Jan 06 2015
    Badass 87 Mazda RX-7 Turbo
    Vaughan Ontario Canada
    Vag Cable relief Vaughan area
    I've been on the forum for sometime, even more so before I registered. My first upgrade I bought for my 2011 S4 was the Ross tech Vag cable. This was prompted by a check engine light which was later discovered to be a nuisance code.
    I want to help out our community by extending out my cable too other S4s. Do you want to clear the annoying MIL? Do you wanna lose the "wink" when signalling or do you wanna add Video in Motion (VIM)? Etc I can help out. Private message if you're u are interested!
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    Exclusively to S4's?
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Jan 06 2015
    I referenced S4 (b8 platform, to be exact) bc I know these cars well. I wouldn't limit it to the s4. It really depends on what you are wanting to begin with.
    Jan 06 2015
    I just completed a b8.5 shift knob for a friend of mine.
    Nov 28 2015
    Ontario, Canada
    Do you know if there is a similar shit knob for the 2013 S6
    Jan 06 2015
    I have seen s6 owners change out to s-tronic knobs. Same knob, different name.
    Jan 06 2015
    You would still have to heat up the pin and rotate to accommodate this knob.
    Established Member Two Rings redlineracer's Avatar
    Nov 21 2015
    Toronto / ON
    sent you a PM
    Active Member One Ring Drewlocks's Avatar
    Feb 19 2016
    Are there any local shops in the gta that can do the knob switch.?
    Sent from my SM-N900W8 using Tapatalk
