Results 1 to 17 of 17
    Jan 26 2016
    london/ON/canada
    KO4-015 turbo upgrade
    I recently bought a KO4-015 turbo. My b6 is 2002 1.8t , my question is... Should the turbo fit right in? Straight bolt in?...
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Yessir it does. You will need a retune and bigger injectors for any significant performance increase.
    Apr 01 2005
    one wagon one truck
    Michigan
    ^ what brand did you go with?
    2009 Audi A4 avant, ECS CAI, Malone stage 2 tune, etc.
    1995 Mazda Miata Montego blue with tan
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors. - Gone
    Dec 11 2015
    PA
    Also, if you're on the stock clutch, what is the max power you can do with the k04 and injectors?
    I noticed some oil in my brothers intake, so the turbo seals are going and its on its way out. I can source a K04 for $300, so I may just do that. Just trying to figure out what the performance is if I go that route. Thanks!
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Quote Originally Posted by iksnoved25 View Post
    I went pretty much as far as you can on a built k04 with a stock clutcb. I made about 35k before I decided to go big turbo. When everything was apart I inspected my old pressure plate and disc, surprisingly it looked good! I didn't beat on my car the whole time though. I should clarify I replaced my clutch at 100k and at 135k I took it apart and my inspection is listed above. Loved my k04 btw, you will not be disappointed, maybe wanting more but not disappointed.
    Dec 28 2006
    Western Maryland
    A little bit of oil in the intake is normal. It doesn't necessarily mean that the turbo seals are bad.
    Just swapping a K03 with a K04 without doing anything else isn't going to gain any appreciable performance. In order to make use of the K04 you will need to get the proper tuning as well as larger injectors.
    How long the stock clutch will hold up is pretty hard to predict. Too many variables. How many miles on the stock clutch? Mostly highway or mostly stop and go miles? Was it babied or abused?
    Dec 11 2015
    PA
    The stock clutch is actually on its way it. Doesn't grab well going into first. I just cleaned the throttle body. Maybe I'm just over analyzing it, but it stood out to the guy who is helping me with the alternator. He also noticed a little bit of sludge under the oil cap, so after I get it running again I was gonna get it cleaned with a sea foam treatment.
    If the turbo does need to be replaced, I would do it right and get the injectors and tune with the ko4. Since clutch needs to get done also, if you recommend going to an updated clutch, I'd do that as well.
    Dec 28 2006
    Western Maryland
    I guess it all depends upon your budget and driving style. I'm running a Valeo clutch kit that you can find for around $400. So far it's holding up to my F21L just fine. For several hundred more dollars ECS and JHM both have some decent kits that will hold more power than the Valeo. They both come with lightweight flywheels so expect some chatter at low rpm's.
    Dec 11 2015
    PA
    Thanks for all the quick replies. I'm not tryin to shoot for the starts here with power lol, nothing above 275 hp lol
    Dec 30 2014
    South Carolina
    That's shooting for the stars on a k04
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by KHARDa4 View Post
    LOL!! I was thinking the same thing but let it pass. Would definately require a little corn juice to make that happen ;-)
    Dec 11 2015
    PA
    haha, I'm new to this audi stuff, but thanks for not flaming me hah.
    What is a more realistic number for a K04?
    Dec 28 2006
    Western Maryland
    With pump gas 240 ish. Maybe 250 max. APR tuning claims 247 hp. Clicky click®
    Dec 11 2015
    PA
    Thanks! Thats not too bad. What the next step up for power? I think I read frankenturbo somewhere?
    Dec 28 2006
    Western Maryland
    about a year ago I had the good fortune to test one of the Motoza tuned prototype F21L mixed flow turbo kits. Clicky click So far I'm lovin it! Since I was already at 200K miles I was interested in a solid tune without going "balls to the wall". The kit is relatively inexpensive considering all the hardware that comes with it. (Mine was REALLY inexpensive;-)
    I'm currently running 20 pounds of boost and putting out around 280 hp. If you really want to push it it's capable of producing a lot more power. I know G-Ride from down under is working with Motoza on an E85 tune and is well beyond 300 hp. We have been comparing files and the last one I saw was over 330 hp. Overall I think it is a pretty good option for the expenditure.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Those are crank HP figures. After you factor in quattro drivetrain losses youre looking at ~200 wheel hp. Luckily however youll have a lot of torque down low, so itll feel quite peppy.
    2019 SQ5 Prestige
    Dec 30 2014
    South Carolina
    Yup :) Doing another corn feed turbo. We'll see how Dave tunes a big turbo on e85, he's yet to do one I believe.
