Results 1 to 40 of 56
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    034 Rear Sway Bar - Sheared off body at mounting point - What do I do?
    Explain me how this happens?
    I have the 034 bar set to "stiff" along with their recommended 034 end links, both of which I bought on the original group buy when it first came out. The thing has been awesome until now apparently. Pics do better so describe what happened. This is on the driver side. Passenger side was fine. The bar is just kind of flopping around under there right now. I have never tracked or auto-x'd the car & it's my daily driver. Is this something that I can have a shop weld back on? It just looks like steel based on the rust on the parts that were ripped off. Kind of a crappy thing to find on a Sunday morning...
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Wow, never seen that before. Im sure a shop would have no issue welding that back on for you. It looks a bit bent too. I'd have them look at the other side and see if they could toss a small brace on there to avoid coming back for the same issue on the other side.
    Good luck mate
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Oct 23 2015
    Australia
    Quote Originally Posted by IKE20VA4 View Post
    I have the same bar but not set on stiff setting.I remember when I put mine on just recently looking at those very welds thinking Hmmm.Yes,just release the bar and get the part welded back on-properly.Awesome bar nonetheless....
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Oct 24 2015
    Perth, WA
    Is it just me or is that RSB installed upside down? Imagining that as it was when welded, you look like you had it in a U shape rather than a n shape. Hard to explain, but it should be like an upside down horse shoe, not the other way around. If this is the case, it may be the cause.
    My respray thread
    Apr 08 2005
    Portland, OR
    It was installed in a rainbow shape, if that makes any sense? Like an arch.
    Oct 24 2015
    Perth, WA
    Ok, cool.
    My respray thread
    Apr 08 2005
    Portland, OR
    Quote Originally Posted by Okedokey View Post
    Ok, cool.
    Yeah, it is swinging pretty freely at the moment though...
    Jun 17 2013
    jersey city nj
    This happened to me . Mine was set on the soft setting with stock end links. I dont track my car at all. Just some free spirit sometimes. But the break was where the rsb mounted on the bracket. It had stressed cracked in half only leaving 1 mounting point left to hold the rsb in place. It would squeak over bumps. I had http://www.driveautoworks.com/ in Clifton fabricate a new repair bracket and weld into place. Has been over a year ing an no issue's.
    Established Member Two Rings XanRa's Avatar
    Mar 25 2014
    Cincinnati
    Anxious to see if 034 responds to this and or what they'll have to say
    2012 CLS 550 4matic - eurocharged (blasphemous I know)
    2016 Q5 2.0T - wife mobile - stock
    _______________________________________
    2008 A4 2.0T quattro - lots of mods - gone
    1993 Audi 100cs 2.8 quattro - gone
    Jun 17 2013
    jersey city nj
    Its pretty common problem in the B5 world from what I was told
    Apr 08 2005
    Portland, OR
    Quote Originally Posted by vce1232000 View Post
    Hmm I didn't find those coming up when I searched. I did limit my search to B7 though... That's not real good to hear though...
    Apr 08 2005
    Portland, OR
    Quote Originally Posted by XanRa View Post
    Yeah, ditto. They are usually very helpful and Johnny on the spot.
    I was going to email them but all they have is a phone number and one of those "fill out a contact form" thingies, which I wasn't going to be able to attach a picture to, so I bagged that for now.
    Jun 17 2013
    jersey city nj
    Just part of the modding game
    Jun 27 2011
    I don't really see how this is the fault of 034. You (and vce) are the first two people I've heard of this happening to across the b6 and b7 platforms. I ran mine on soft for 3 years on my 2004 b6. Granted it had zero rust anywhere but the brackets were solid when I removed it and put the stock bar back in. I jmguess t never occurred to me those brackets wouldn't be up to the task. A shop could definitely weld those back on though. Access is pretty easy so I bet it wouldn't take them more thank 30 minutes including getting it on the lift.
    That sucks though. I wonder if the residual rust had a large part in weaning that factory bracket weld
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 23 2015
    Australia
    In reality it would take a lifetime for rust to eat through those welds,they are typically more resistant than the parent material....
    But as NY knows,rust never sleeps..........
    Oct 24 2015
    Perth, WA
    Could this be caused by improper endlink set up?
    My respray thread
    Apr 08 2005
    Portland, OR
    Not trying to place any blame on 034, just seeing if they have any advice for others with this issue or without it.
    It is a CA born, OR raised car with no other noticeable rust. This rust appears to have taken root post shearing off.
    Apr 08 2005
    Portland, OR
    IDK. I'm not the expert. That's where y'all come in..
    Mar 08 2011
    union, nj
    Seems like a weak point on these cars... Maybe that's why the Neuspeed sway bar comes with a reinforcement bracket to weld to the stock one. Neuspeed did their homework on this one.
    Jun 27 2011
    Quote Originally Posted by 08 classic View Post
    You mean the b5?? It's not a weak point on the b6/7 chassis that I've ever seen or heard of.
    Edit: just saw neuspeed's bar that you mentioned. Never heard of it before. I don't know, those brackets don't look particularly beefy.
    -CP
    2017 Q7 3.0t
    Mar 08 2011
    union, nj
    I always wondered why they choose to add this bracket with their sway bar. From my understanding its supposed to be added to the oem brackets. I am going to upgrade mine at some point, this stuff catches my eye to see if I can improve or take other things into consideration.
    Apr 08 2005
    Portland, OR
    Yeah, I never would have thought it being a weak point until I saw the metal ripped in half! It is kinda on the thin side...
    Also, thinking more about "why my car" among the many that are running this 034 RSB. My work has a driveway that is a right turn into it that I take everyday and it is probably a 30-40 degree slope that rises up about 24" which gets you over 2 sets of railroad tracks into our lot. I could see that angle putting some serious stress on things. I'm on stock sport suspension other than B5 caps and the RSB + endlinks and I feel like it gets onto 3 wheels sometimes when pulling in.
    Jun 27 2011
    I think "why did it happen in my case?" Is the operative question here.
    Regardless find a shop who can weld them on and talk to them about reinforcement. I bet there are some gussets they can weld on to keep it on there nice and sturdy.
    -CP
    2017 Q7 3.0t
    Jun 17 2013
    jersey city nj
    I dont blame 034 at all. Figure that a beefed bar has consequential results to weaker stock oem designed mounts for a smaller bar. No biggie for me. I just got it ed and moved on Again all part of the modding game
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    This happened on my b5 s4 avant because i was running a sway bar without re-enforcement brackets. Ive never seen a b7 bar that came with any re-enforcement brackets so i didnt think this was an issue on the b7 chassis.
    Maybe 034 and other companies can develop a re-enforcement bracket to add to this RSB to prevent this ever happening.
    Here are some brackets from the b5 world
    HSPORT
    NEUSPEED
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by nizmosx View Post
    HSPORT
    NEUSPEED
    you for chiming in and confirming .....
    Apr 08 2005
    Portland, OR
    Good to know. Waiting for a quote from the shop on welding it back on and reinforcing it a bit on both sides! I'll post back up once I hear back.
    Sep 17 2005
    Fremont, California
    Whoa! I'm sorry to hear about this issue on your car.
    As others have mentioned in this thread, the B5 chassis was notorious for having rear subframe failures, even with the stock rear sway bar. For that reason, we make our Billet Aluminum Subframe Reinforcement Kit to use with our rear sway bar on that platform.
    It looks like the combination of the stiffer rear sway bar and some corrosion at the welds caused the sway bar brackets on your factory subframe to detach. We'll look into this a bit further, and I'll update this thread if we come up with a solution for the B6/B7 chassis.
    We tested this bar from day one on my personal car (B7 Audi A4 2.0T) and the subframe is still in great shape years later, but my car is not exposed to snow/salt as often as cars located in other climates.
    - Laszlo
    Oct 24 2015
    Perth, WA
    Also if you do get it welded back on, make sure you put a protective epoxy style rust prevention coating over the area.
    My respray thread
    Apr 08 2005
    Portland, OR
    Ouch. 3 hours of labor to re-weld and paint for corrosion protection so looking at roughly $300. The shop said they had to take the wheels off and remove and re-install the sway bar.
    Does that sound fair?
    Jun 17 2013
    jersey city nj
    I dont understand why the shop had to the wheels. I and re- by 034 RSB in less then 30 minutes and didnt have to the wheels. Corrosion protection is nothing but rust inhibitor-undercoating out of a spray can. In fact when I my sway bar bracket I didnt even re- the RSB. I just removed the RSB bracket on the passengerside and swung it down and then the shop did the welding from there. But 300.00 is still cheaper then buying a used rear subframe and everything over
    Jun 27 2011
    Could you remove it yourself and drive there? The handling will suck but having no rear seat installed won't hurt anything.
    -CP
    2017 Q7 3.0t
    Jun 17 2013
    jersey city nj
    No rear seat
    Apr 08 2005
    Portland, OR
    Yeah, don't know why they a) had to remove the wheels either and b) had to completely remove the rsb.... Might need to get a 2nd opinion tomorrow.
    Apr 08 2005
    Portland, OR
    No rear seat
    Yeah? Sedan? They didn't mention anything about needing to take out the seat...
    Jun 27 2011
    Rear seat. Rear sway. Siri autocorrected me. Dumb broad...
    But seriously though, couldn't they just swing the bar down and out of the way, weld that stuff on, hit it with paint, and be done? Why do they need to remove the bar and the wheels?
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    Id rather spen 300 and get it professionally welded.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    The chassis was only designed for so much force. I would say the failure mode was more a function of fatigue as opposed to corrosion. Its a common failure mode with fillet welds.
    2018 A5 S-Line Manual
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by konarider94 View Post
    Id agree with that only if we saw many of these issues. I think this is rather rare.
    My respray thread
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    I don't mean its common on the car or for this particular part. There are a lot of things that affect fatigue life and this may have had a defect to make it an issue. There is something called an endurance limit. If your stress stays below the endurance limit fatigue failures should never happen. Obviously cant say for sure why it was a problem looking at pictures, but I'm just saying its a lot more likely related to that as opposed to corrosion, especially being a fillet weld.
