Results 1 to 21 of 21
    Jan 12 2011
    2016 Q5, 2018 S90
    Not particularly obvious maintenance items
    Is there any preventative maintenance I can do to keep my car performing like new for its lifetime, aside from whats in the Audi maintenance schedule? I'm currently at 42k miles and will be out of warranty soon enough. I like to keep up with the maintenance as best as possible. Are the some less obvious things any one does to their car?
    Also does anyone use an excel to keep track of their maintenance records?
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    8 speed transmission fluid and filter change at 50k, differential fluid change as well....
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Jan 12 2011
    2016 Q5, 2018 S90
    Quote Originally Posted by hyperunion View Post
    Thanks, I've been looking that up. I haven't found a consensus, some people recommend longer intervals for that. Is the timing chain in our cars a pertinent issue to be replaced? Water pump, thermostat, etc..
    Established Member Two Rings uberwgn's Avatar
    Mar 29 2011
    '06 A6 Avant, 2015 Q5
    Boston suburbs
    fuel filter change out. Transmission service.
    '06 A6Q Avant | '11 A4Q | '15 Q5
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Power steering fluid, carbon cleaning, coolant flush
    2016 S3
    Instagram- @Thisisastickup
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Trans/diff fluid change every 60k, brake fluid every year, coolant every 2 years.
    OEM scheduled maintenance usually tops off those fluids, not replaces it.
    Jan 12 2011
    2016 Q5, 2018 S90
    Quote Originally Posted by BMWManiac View Post
    Thanks looks like I have some overdue maintenance. Also what would you recommend for replacing coil packs?
    - - - Updated - - -
    Quote Originally Posted by b6Hate4 View Post
    I was looking into getting the carbon cleaning this spring, thanks for the tip!
    Jan 19 2016
    Orlando, FL
    Quote Originally Posted by DontHait View Post
    - - - Updated - - -
    I actually meant 30k for the trans/diff fluids! Also, forgot fuel filter....I like to do it every 2 years. For coils, that is a tough one. I am starting to see a lot of folks replacing or upgrading to the R8 coils? I would see coils as needing replacement something around the 75k to 100k miles.
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    May 10 2015
    Pittsburgh PA
    As far as keeping maintenance records goes, I keep a binder with all of my parts and service invoices saved in plastic sleeves ordered by date. To go along with the parts invoices I like to type up a short maintenance summary of what I did, with date and mileage as well. It's good a good reference if you can't remember when you last serviced something and it probably comes in handy when you go to sell your car.
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
    Jan 12 2011
    2016 Q5, 2018 S90
    The trans and differential fluids actually need service that often? That's news to me. Great advice from everyone who has replied so far, I really appreciate it
    Jul 16 2008
    Finland
    30k is really low for diff fluid. I plan on doing mine at 60 k miles along with my 6MT fluid.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I you want the auto-transmission to last....change the fluid and filter every 30,000 to 40,000 miles.......
    Differential gear oil (front and back) and Manual Trans gear oil can be done every 50,000 to 60,000 miles.
    Change your power steering fluid every 30,000 to 40,000 miles too.
    Replace your coolant (and only used distilled water to mix with the concentrate) every 50,000 miles.
    For all the above, make sure you are using the correct fluid...I stick to original VW/Audi stuff to be sure.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Crap, I've never flushed my coolant or power steering fluid.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Nov 29 2015
    Utah
    My plan is this -
    Coolant - 50k
    Diffs - 60k
    Oil - 5k
    Power steering fluid - 30k
    Plugs - 30k
    Trans fluid/filter - 30k
    Brake fluid - 2 years
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by blbroo View Post
    Yikes.
    Coolant aint that big of a deal. Most dont ever flush it.
    2016 S3
    Sep 03 2012
    Lehigh Valley, PA
    Yikes.
    50k for coolant seems pretty reasonable!... Tho mine is close to 4 years ownership but only 27 k miles!...
    Oct 26 2012
    St. Louis, MO
    Yikes.
    Gives me something to do with the car now.
    Stay classy.
    May 22 2013
    Southern ME
    I'm failing with a search, is there a power steering flush DIY anywhere? Looks like this is the stuff to use?
    Pentosin CHF 202
    Jan 12 2011
    2016 Q5, 2018 S90
    Anyone have information on the timing chain tensioner?
    Oct 26 2012
    St. Louis, MO
    There are a few threads from yesterday on this topic.
    Quote Originally Posted by asfastas63 View Post
    Pentosin CHF 202
    Here is a procedure from the B6 section. I'd assume it is similar.
    http://www.audizine.com/forum/showth...steering+flush
    Looks like you suck all of the old fluid out of the reservoir then add new. From that, you start the car for a couple of seconds to consume the fluid in the tank and push the old out into a catch container. Keep repeating the fill and drain until new fluid starts coming out the drain side.
    I would think I could use my power bleeder to make this easier, if there is a cap that fits the power steering lid.
    Jan 12 2011
    2016 Q5, 2018 S90
    I'll scroll through for them, thanks for letting me know
