Results 1 to 24 of 24
    Jan 08 2016
    Los Angeles, California
    TDI Intercooler Upgrade
    There appear to be a couple European vendors selling these but I couldn't find any reviews or even mention of them on this forum. Can anyone chime in on this mod, i.e. direct replacement and pros and cons? Thanks!
    Established Member Two Rings DanMontgomery's Avatar
    Jun 07 2014
    Clarksville, TN
    Been looking at the Darkside Intercooler for my TDI.
    http://www.darksidedevelopments.co.u...-platform.html
    I been talking to them for a while now, just haven't pulled the trigger yet.
    They do answer questions (emails) fairly quickly and seem to be very knowledgeable.
    They told me the intercooler is a direct bolt on...however they have actually installed one on a 3.0TDI Q5.
    They offer other TDI parts, upgraded Turbo, Tune, and DFP delete down pipe.
    They will paint (spray) it all black for just a few pounds more.
    Price is in British Pounds...so make sure do your conversion.
    My overall assessment...going to get one. It will work into my overall plan to get the most from my TDI, just want to wait till this emission ordeal is taken care of first.
    V/r
    Dan
    2013 Audi A4 (Hanz) Prem + 2.0T Quattro Monsoon Gray
    2013 Audi S5 Prem + 3.0T Monsoon Gray
    2014 Audi Q5 (Ann) Prem + 3.0 TDI Scuba Blue
    2015 Audi Q5 (Franz) Prem + S-Line 3.0 TDI Daytona Grey Pearl
    Jan 08 2016
    Dan, did you remap your tune after the intercooler install or it works fine on your tune that was already on there? I ask because my Euro SQ5 intercooler finally shipped from Latvia and I will hopefully install it soon after it arrives.
    Jun 07 2014
    Clarksville, TN
    Quote Originally Posted by Pittdawg View Post
    Not sure what tune your running but I didn't have to redo or make any tune adjustments.
    Currently running a ChipWerke Pro.
    V/r
    Dan
    Jan 08 2016
    I have the APR tune. The reason I asked is I've read conflicting accounts as to whether our ECU can compensate for a larger intercooler, i.e. if it can't it could throw out of whack the Air/Fuel ratio and possibly cause a too lean or rich condition.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    If by "out of whack" you mean more power and better efficiency, then yes.
    It lowers your intake air temperature, so the ECU can increase boost and timing. That's all.
    Jan 08 2016
    Quote Originally Posted by SQive View Post
    If that's the case I'm a very happy camper. I can understand the ECU not having to pull timing and reduce boost as often because of the cooler air but not sure how much it can decide to advance timing and increase boost to create more power above and beyond what it's currently mapped for. In any event it was literally just delivered and I'll hopefully be able to have it installed soon. It's rather large and quite heavy:
    Apr 26 2014
    DFW
    Weight is relative, but that looks a lot smaller than the APR CPS.
    Of course, every little bit helps, so slap that bitch on there.
    Jun 07 2014
    Clarksville, TN
    Can you get a picture of the both intercoolers together?
    V/r
    Dan
    Jan 08 2016
    Not sure but I'll try. Here is the post with pics that first got me going in this direction:
    https://www.drive2.com/l/471652831116394674/
    Apr 26 2014
    DFW
    Never mind. . .this is a TDI thread.
    Apr 09 2018
    Aussie land
    Hey guys. Has anyone got an videos of a tdi exhaust with dpf delete?
    Jan 08 2016
    I don't have pictures of the install but it took my mechanic the entire day and much custom re-working and modifying the stock 3.0 TDI charge pipes and hoses to fit the 3.0 BITDI intercooler. Nonetheless, everything appears in order and it definitely feels stronger especially the mid and top end. If my Torque Pro app is accurate boost appears to remain essentially the same as before. Assuming the ECU can adapt somewhat to the larger/cooler volume of air I only expect even more improvement
    Apr 09 2018
    Aussie land
    Nice!!! Hows the noise??
    Aug 13 2017
    Phoenix AZ
    +1
    Quote Originally Posted by dingdong555 View Post
    Jan 08 2016
    It's an intercooler, not much if any sound change.
    Jan 08 2016
    Quote Originally Posted by DanMontgomery View Post
    V/r
    Dan
    Sorry I wasn't able to but I can confirm the BITDI intercooler is wider and longer with cast aluminum end tanks and about 10 liters overall compared to the stock 8 liters or so. It physically mounts up perfectly in the OEM location but needs a fair amount of modification of the OEM hoses and charge pipes. If I had an easier way of identifying the OEM part numbers for the BITDI hoses and charge pipes I'm sure that would be better but so far so good.
    Apr 26 2014
    DFW
    Why don't you ask some of our friends here from across the pond?
    Jan 08 2016
    Anyone in particular? I barely get any responses to TDI related questions I post here; apparently TDI owners are more the hypermiling type then the modding type, which I understand.
    - - - Updated - - -
    With that said it definitely feels peppier and freer revving.
    Apr 26 2014
    DFW
    I don't know if he's still on here, but check @IANSQ5.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    - - - Updated - - -
    Try the tdiclub forum
    1 of 1 in the United States - 2015 A6 TDI Prestige with 19" Sports Package and Season Dedicated Tires - Oolong Gray Metalic, Nougat Brown Interior, Dark Brown Walnut Inlays, Black Headliner, Driver Assistance Package, Cold Weather Package, Night Vision Assistant with Pedestrian Detection. Summer - Michelin Pilot Super Sport. Winter - Yokohama Bluearth Winter V905. Eurocode Sway Bars and Links. XPEL Ultimate.
    RIP - 2005 A6 4.2 - (February 2005 - August 2014) (142,000 miles)
    Jan 08 2016
    Quote Originally Posted by Kevin1 View Post
    I've search all the websites; hence the reason I posted a link to an obscure European blog.
    Oct 19 2008
    Long Island
    Wow. I find that forum to be extremely active with all sorts of posts regarding APR, Malone, etc.
    Jan 08 2016
    Yes I have found a few helpful posts on there but absolutely nothing about upgrading to the SQ5 intercooler. I may be the first in the U.S. to do this as far as I can tell ;)
