need a little help from the S4 experts -
I am in the process of the timing guide replacement on my 06 B7 S4, and seeing that the engine is torn down to this degree, have made the decision to pull the heads for rebuild. Here is the question: what is the exact specifications for the tool to remove the head bolts? I ordered a tool off of amazon that claims to to be the one needed, but does not fit. WTF? I am having trouble finding the correct tool.
Any insight that you all may have is greatly appreciated.
BTW - I debated about removing the heads for quite some time. My S4 skipped a tooth on timing and have an ever most slightly contact with valves on the pistons on one bank. After reading about dropped valves on engines after the valve guide replacements, I got spooked and decided to go the extra step.
