Results 1 to 3 of 3
    Active Member One Ring hmoya0311's Avatar
    Sep 22 2015
    Orlando/Miramar
    Engine piece needs replacement
    Hey guys! I was trying to solve the headlight range control defective problem and I noticed a piece looked really old!
    Does anyone know what this is? It also looks like it needs replacement haha
    It was here
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    If your looking at the mesh filter, it's called a snow screen I think. It's a pre-filter for your air box and should be cleaned occasionally. Just take it out and wash it.
    2011 A4 Avant
    Jun 26 2009
    Bremerton WA
    If you are referring to the mesh filter, its a snow screen. If prevents snow coming thru the grill being sucked into the paper element air filter. Just wash it with soapy water. The intake manifold is open like that. Its only covered by the upper airdam that is held in by 4 screws.
    Looks like I type a little too slow.
    VMR 710's, APR software, Eurocode HFC
