Results 1 to 8 of 8
    Dec 18 2008
    Virginia
    fitment question on Miro 111 with 19 x 9.5 et 40 on my b7 avant in front
    I read a bunch on this and still a bit unsure. Does anyone think I will have issues running this wheel with a 235/35/19 in the front and back? I read a thread where the guy had issues in the front. Not sure if it was because maybe he was lower than me? I'm on eibach pro springs/koni fsd. I like the idea of the 9.5 everywhere due to the extra concavity. I see Element wheels offers a staggered set up with 19x8.5 et32 in the front. Just wanted to double check with the experts here based on my setup. I don't mind running spacers if necessary.
    Thanks
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    Quote Originally Posted by mudd1011 View Post
    I read a bunch on this and still a bit unsure. Does anyone think I will have issues running this wheel with a 235/25/19 in the front and back? I read a thread where the guy had issues in the front. Not sure if it was because maybe he was lower than me? I'm on eibach pro springs/koni fsd. I like the idea of the 9.5 everywhere due to the extra concavity. I see Element wheels offers a staggered set up with 19x8.5 et32 in the front. Just wanted to double check with the experts here based on my setup. I don't mind running spacers if necessary.
    Thanks
    Do you mean a 235/35/19 tire?
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Yes the 111s in 19x9.5 et40 with 235/35/19s works fine and clears A4 and S4 brakes.
    Dec 18 2008
    Virginia
    Yes. 235/35/19
    Dec 18 2008
    Virginia
    Thanks. Chris I went to your website and didn't see any miro 111. Do you no longer sell them? Or maybe I went to the wrong site?
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    You might need a very thin spacer depending on what brake rotors you're running. On the stock rotors they cleared the front brakes (not by much). But when I got Adams rotors, the rotor hat was a bit thinner than the OEM rotor, so the spokes hit the caliper. I went ahead and ground the caliper down due to time, but theres a chance you'll need a 2-3mm spacer. This was with the 19x8.5 et35 wheel, but the 9.5 et40's have less brake clearance from what I've heard due to the concavity. As far as fender clearance you're fine.
    Dec 18 2008
    Virginia
    thanks for the info. I think I have the OEM rotors ( I replaced all four a couple of years ago but forgot what brand I thought I kept it OEM.
    Oct 04 2012
    Everywhere
    They aren't on the site, but I am still a dealer and can get them. I sent you a PM.
