Results 1 to 3 of 3
    Jan 22 2012
    East
    Dealer removed apr tune program switching still there?
    Hey guys. I took my car in for a leaking taillight warranty work. They replaced the tail light but also updated the regulator valve because there was a recall campaign on it. Apparently they also reflash my ecu... When I try to do the program switching, I still see the double, triple, and quadruple flash slots, but no single flash. The single is more of a constant. Is this just the normal stock flash pattern? Both the apparent single and triple slot feels the same.
    I tried to complain to them that they should have notified me before doing anything else, but wasn't able to get anywhere with that. The closest apr shop charges 115 for a reflash...
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    Apr does not charge you for reflashing, but the dealer may charge labor costs. That shouldn't be more than $50.
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Jan 22 2012
    East
    Not in the DC area. What shop did you use? I'm driving across country in March so may be able to stop by a cheaper shop along the way.
