Results 1 to 4 of 4
    Active Member One Ring hmoya0311's Avatar
    Sep 22 2015
    Orlando/Miramar
    Anyone in Orlando area with VAG-COM
    I recently changed my OEM HID to Blesk HID 5000K bulbs and I had to take out the headlight assembly. After I turned on the car with the headlights installed I forgot that I didn't connect the power cable to the passenger headlights. I fixed it and then the car gave me a "Headlight Range Control Defective!" Error and I read that you can get your headlight to level and fix the error using a VAG. I'm a college student and I don't have the budget to invest in a VAG cable. So it would be appreciated if someone could let me use theirs or help me solve this!
    Sep 22 2015
    Orlando/Miramar
    BTW I'm in the UCF area
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I know it's not local but I'm in Tampa if you wanna make the day trip. Another gentleman from your area is coming here for some work also.
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Sep 22 2015
    Orlando/Miramar
    It's only an hours and a half so I could make the time one day! I'm gonna check out the headlights and switch the bulbs out and put them back in to see if it makes a difference, just in case I put them in at an angle or something. But, if I efforts don't work I'll contact you! Thank you!
