Results 1 to 10 of 10
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Control arm bushing?
    So I installed H&R Sport springs on my car yesterday and noticed the control arm bushings are worn/cracking. They are on the smaller side so that may be normal, but the car only has 40k. New oem arms are $350 each and bushings are $50 each from my local dealer. Input on aftermarket arms?
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I just ordered meyle lower control arms from europa. Around 150 for lower rears. People seem to stand by their products
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    If you are on Sport springs, you may want to go with adjustable arms like the SPC's (you'll be around -2 degrees with those springs). Otherwise, OEM bushings or Meyle HD arms/bushings are good options.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jun 19 2014
    toronto
    You can swap bushings with whiteline.
    They make stiffer ones than stock - you can get the eccentric ones or centered ones.
    Both upgrades over OEM and will last longer.
    Dec 30 2015
    Sacramento, Ca
    Thanks for the info fellas!!
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    I don't know when exactly you bought your car. But if it has warranty and the dealer is friendly you can claim that they are busted/torn and might get warranty replacement. If not I would go with the bushing and just replace them, Since it seems like you know what your doing due to your Caddy. I would just buy the ones you can press in to save you some coin for something else. Unless you have no way to press them out and back in again. Then I would go with new HD arms.
    Dec 30 2015
    Sacramento, Ca
    I thought about warranty thru the dealer, but I'm not sure how many years/miles were issued from the factory on 2011's. Figured it was worth a phone call to them atleast. I don't have a press so after looking at the options, I would use the mylie hd units...they look nice for the price.
    Will
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by boro92 View Post
    I keep forgetting about the Whiteline bushings. I may give them a try soon. I've used their bushings on other cars, and been very happy with the results. The eccentric bushing that allows for some (fixed) camber adjustment is a nice option.
    Nov 13 2014
    Wife's MK7 GTI
    Land of Gold Chains, NJ
    Are u sure they are really cracked/worn? I replaced mine at 7,000 miles, and less than a year old, for adjustable UCAs so I could add more camber. My first impression was that they were cracked as I could see white dust laying in the "cracks" but after getting them out and getting a closer look, they were fine. After looking into the design, it surprises me that they don't rip on the first day, but it is some high quality rubber. It wouldn't hurt to replace now anyway, they will eventually become a problem. Good luck
    2015 S4 / Ibis / DSG / Prestige / Sports Diff / ADS suspension
    Mods: CR-15 strut bar / EC sway bars / EC end links / Alu Kruez / 034 trans insert / AMS heat exchanger kit / ECS intake / SPC upper control arms / APR stage 2
    B6 A4 / 1.8t / stage1 / coilovers / sway bars : Sold
    1987 Buick Turbo T / Big Turbo / so fast, the motor was strapped to the frame Sold
    Sep 28 2013
    B8S4, C300 4matic, Honda CR-V
    Mine cracked at 55k. They got replaced with SPC.
    edited for grammer
    interior and license plate LED lights, E-code headlights with 6000k bulbs, AWE catback, H&R OE springs, APR Stage 2, 19" BBS RGR (summer), stock 18" with 15mm and 20mm spacers (winter), carbonio intake, lots of VAG mods, 35% tints all around, lots of road rash, 034 transmission mount insert, SPC ACS, Spulen rear diff mount, Bilstein sport shocks, CR-15 strut brace bar
