Results 1 to 16 of 16
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    Front caliper leaking??
    I noticed a noise coming from the front of the car... Decided to have a look at the brakes. I thought maybe something started to grip or seize. Removed the caliper to check everything... And noticed what appears to be a leak all around the caliper. I thought it was water at first but it looks like brake fluid. I think. Everything is messy right now, it's winter here, it's ugly, wet and... messy, and hard to tell. Anyhow, I applied grease to the pins and cleaned the pads contact area as much as I could. I didn't test drive yet but I doubt it solved the problem. My feeling is that the caliper is on its way out and is starting to seize...
    What do you think? I don't believe it's very hard to replace... Is it?
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Brake fluid doesn't run through there. Maybe you need new guide pin boots.
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    It's weird though, it's all around like that. On the other side of the caliper too... They're made of two pieces right? It looks like the join is leaking or something, if that's even possible.......
    Guide pins looked ok...
    Feb 24 2004
    Minneapolis
    Not sold on the leaky caliper theory. It would leak from the piston and that rubber seal. And if so, gravity would pull it down. Since it's upside down in the picture, I'd expect the fluid to be pretty visible at that rubber boot. Looks more like something that's been thrown off the rotor to me.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    I know it should leak from the piston... I'm unable to explain what this "leak" is... And it's not thrown by the rotor, as I said it's like that all around the caliper (so under the caliper on the picture) and there's no way stuff thrown from the rotor could end up there.
    I did a test drive last night, the sound I was hearing is gone for the moment, so my cleaning job did the trick. I'll check from time to time to see if this "leak", or whatever it is, get worse.
    Thanks for the feedback!
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    That's strange. Is your fluid level down at all?
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    No. But I'll keep monitoring...
    Sent from my SM-T700 using Tapatalk
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Acme View Post
    If you end up needing to replace calipers, I should have 2 fronts I could sell to you.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    Quote Originally Posted by JDillon15 View Post
    With the weight of these things, shipping would be quite high I think.... Probably easier to get one from the scrapyard not far from home, if they have what I need...
    Jul 11 2014
    Chicago, IL
    Pretty sure I can get it in a flat rate for $20, or I can usually get a pretty accurate quote. Just let me know if you're interested and we can work out the details.
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    I'm in Canada. Things are never simple, nor cheap!
    But yeah, cool. I'll let you know as soon as I figure out WTH is going on with this thing...
    Jun 27 2011
    The main "body" of the caliper is one aluminum casting. The piston has no way to leak except out the fluid line or the boot. The outer carrier part is iron and just bolts to the main body. Its never a bad idea to service the caliper, new slider pins and boots, new piston seal and boot, regrease, etc. Its fairly involved and you're best off removing the caliper which then leads to a brake fluid flush also, but none of it is really that hard, just time consuming and your car is down until you finish.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    So if the caliper is one single piece of metal, there's no way this is brake fluid. And I looked at the boot, it's totally fine. So I don't know what this is... Maybe it's just some condensation from the car being in the garage in winter, and it's just water. Although I can't explain why it's there, and not all over the other parts of the caliper. The grinding noise I was hearing before was probably from the pads, I cleaned everything (it was overdue) and it now looks (and sounds) okay. I'll keep an eye on this so-called "leak" though... just in case...
    Nov 15 2011
    Montreal | I sell in USD
    I'll have two calipers up for grab loaded with close to new Posi quiet pads as soon as I put the Q5's on. And JDillon15 it wont be 20$ lol
    *****I sell in USD*****
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Axis View Post
    Yeah he PMed me. Didn't realize he was in Canada. Lol
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    So, was looking for pics of the calipers on our cars... and found this in a DIY on AZ that (wrongly) explained how to do front brakes on a B7 A4. It is unnecessary (and as I understand, not recommended) to disassemble the calipers this way to do your brakes... I didn't do that when I did my brakes...
    What he did though, is show me that it's impossible for anything to leak from there. So it's most probably condensation or just water sitting there... I feel dumb.
