Results 1 to 14 of 14
    Jul 01 2015
    NS Canada
    Spacers for stock 19" rotors
    I am putting back on the stock Titanium Rotors (8.5J x 19) with stock continentals rubber in the spring (once the rubber wears out I'll buy new wheels).
    I want to add spacers and have the wheels as aggressive as possible without rubbing while moderately lowered (say one finger above wheel to wheel well)
    I have et35 winters, and they are close, but I'd still want to add a 2-3mm up front, and maybe 5 in the back if this was for summer. Anyone run spacers on the stock wheels? Would 10/17.5 work? Appreciate any pics of anyone running this setup.
    Mar 21 2015
    Ecs has that set for factory height but it's not to bad.
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    I have 10mm spacers all around on my stock peelers at stock ride height. I think the stock rotors have the same offset as the peelers.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Aug 15 2014
    8mm and 12mm
    I'm actually running 10mm and 15mm but i'm also on 245/35/19
    For Sale: Mini Part Out
    Apr 11 2012
    8mm all around:
    I'd probably go 10mm if I still ran these wheels, less chances for vibrations, and it will look more flush with the 8.5" wheels.
    Jul 01 2015
    NS Canada
    Do you have any pics?
    Quote Originally Posted by Shimmy View Post
    8mm and 12mm
    Established Member Two Rings Tuneman7's Avatar
    Sep 07 2015
    New York, NY
    I believe their "flush" kit is 8mm in the front and 12.5mm in the rear.
    Quote Originally Posted by cchoi83 View Post
    That's correct, I believe stock rotors, peelers, and clovers are all same offset. I wonder if there's a disadvantage to not going square all around
    Senior Member Three Rings cfritos's Avatar
    Apr 16 2013
    Greenwich, CT
    Quote Originally Posted by Tuneman7 View Post
    i have the ecs flush kit and they are great. 12.5 in the rear, 8mm in the front
    2013 S4 Estoril Blue Premium Plus
    Mods: | Carbon Atlas Inlays | Sport Diff | GIAC Stage 2 | AWE Touring w/ NonRes Downpipes | PSS10 Coilovers | Ziza Super White Fog | Ziza Interior LED | Alu Kreuz | Roc Euro | Passport Max | Whelen Police Lights | Laser Interceptor Dual | Roc Euro Short Shifter | Eurocode USS Sway Bars | RS4 Mesh Grill | 35% Suntek Tint | 034 Transmission Mount | ECS Flush Spacers |
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    i have 10/15s from my old car.. feel as if they might be too aggressive on the peelers to throw on..
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Quote Originally Posted by TomPaul10 View Post
    Your sig says you are using 15f/20r spacers on peelers. Do you have any pictures you can post showing what it looks like?
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Aug 04 2014
    albany, new york
    Quote Originally Posted by DBFL View Post
    yes correction i have 15/20s that where previously on my A5.. feel they might be too aggressive on the S4
    past:
    2016 SQ5
    Active Member Two Rings Lenrock's Avatar
    May 03 2012
    C5 Corvette
    Buffalo / NY
    I'm running A5 18" x8.5s with at ET of 29 and no rubbing at all at stock height for my winter setup. Diameter and width is same as my 19s.
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hello Guys,
    From my own experience, getting a flush look with spacers depends on many parameters :
    - The type of tires : some tires, even with the same dimensions, can be drasticaly wider than others (i.e Michelin PSS vs. Conti's for example )
    So, chances of rubbing are least with narrower tires that are a little stretched.
    - Alignment : the geometrical setup plays a hudge role. Particularly for the rear end where camber is adjustable. ( audi specs are within -0.5 and -1.6° if i remember well, and each 0.1° has the same effect that ~ 1 mm spacer for rubbing. Too much toe in can also lead to rubbing where bumper and rear fender meet.
    - Ride height: the more your are low, the more you have chances to rub, but it's almost dependent on the alignement specs, more than ride height.
    - Chassis alignement !! : i notices than my rear end was not symetrical: for a same spacer size (and same alignement specs): i had ~ 3 mm more room at he passenger side ! (so initialy, i rubbed on passenger side and did not at the driver side with my 12.5 mm ECS spacers). Since i track my car i little bit, i had an agressive camber set up done (-2.0°) and now, it doesn't rub at all with 12mm passenger side and 15 mm driver side spacers . (Yes, I dared ... ;o) )
    So, My general advice should be to care about spacer at the verry end of your chassis mods:
    Drop your car if you want / check and get a proper aligment / have in mind that your tires type plays a role also
    Then, your can start a "trial and error" process. And if you want the best flush possible without any chance of rubbing, your will have to buy different spacers sizes. (10-12-15)
    I personnally have 10 mm front and 12 mm driver side and 15 mm passenger side rear. without any rubbing (with -2.0 ° rear camber and not too much toe in)
    Personnally, I prefer to not put spacers Under 10 mm as they don't have a real centering flange like the original hub. I think without these, shear stress in the bolts are exessive (bolt are aimed at traction stresses and not shear). But, i don't have knowledge of problems with 8 mm spacers (with minimal centering flange), though....
    Please feel free to share your opinion on this!
    Brest regards
    Mathieu
    EDIT: here is the set up:
    (dropped a little more the car since these pics)
    Maybe, i will try 12 mm front and 17 mm driver side and 14 mm passenger side rear (by machining H&R 20 and 15 mm spacers) for a litlle more flush look !!
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Unless you lower your car it will look odd with aggressive spacers. I know you said you were planning this...
    I think 12mm spacers all round are perfect though with OEM offset wheels.
