Results 1 to 2 of 2
    Active Member Two Rings ASAP617's Avatar
    Feb 27 2011
    B6 S4 & MK2 VR6
    Around Boston
    WTB-Catless downpipes for B6 2004 S4 6speed
    Hello,
    like the post says im interested in buying your downpipes from your B6 S4. If you have JHM piggies i'd be interested too.
    Thanks,
    Drive fast or don't drive at all
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    i have stock DPs that can be piggied if needed with brand new flexes welded in 2 weeks before removal. located in nj. 200$
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
