Results 1 to 35 of 35
    Senior Member Three Rings killintime's Avatar
    May 02 2007
    VA
    Is 60k Just Too Much...
    Hello out there...
    Found a very nice "1" Owner 2007 RS4 that is otherwise perfect. However it has 60k on the clock.
    I've owned two 4.2 S4s. One of which was a nightmare. That one being a car I picked up with 69k miles on it.
    Am I in for the same thing here with this car? I know the RS4s are built in a different facility by different technicians but we're still talking a near 10 year AUDI.
    What say you?
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    im sure the other guys will chime in with similar answers but 60k is not bad at all if the key maintenance has all been done. look for things like how many carbon cleans have been performed, have the brakes been done, suspension DRC recall done (is it leaking anywhere), control arms should be done at this point already etc.
    i find that if these cars are owned by enthusiasts and well cared for, 60k is not a lot by any means.
    i would also highly recommend a PPI with a compression test and maybe get the cylinder walls looked at
    Sent from my SGH-I337M using Tapatalk
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Just picked up a 95k mile example. These are higher maintenance cars (DRC, Carbon cleans) But less prone to catastrophic failures a'la the timing chain failures in the "regular" 4.2s. The PPI is always a good idea, but I would not worry about 60k miles. At first I thought the asking price was 60K and I was about to tell you thats way too high! lol
    Oct 07 2013
    Bellevue WA
    I just picked one up with 38k miles on the clock, two previous owners. I'm new to the RS4 - can someone expand on the suspension DRC recall and control arms (issue?) mentioned above? I'll also do a search to see what I find.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    the DRC is the dynamic ride control for our cars. it tends to have some leaks and audi released a recall for the entire DRC system which most RS4s have gone through. its important to make sure (if you plan on staying on stock DRC suspension) that there are no leaks when you buy it, maintaining/repairing the DRC system is a pain in the ass and the system can only be recharged by Audi dealerships. The control arm bushings are known to fail with time and heavy use, check the rubber bushings on your front control arms (sometimes the car will make a clunk noise going over bumps at low speeds) and if they are cracked, you will have to replace the arms or get new bushings pressed in.
    the major issue though is Carbon buildup. carbon cleans should be done every 30-40k (this can vary). neglecting such an issue can be costly and can lead to other problems later on. injectors on our cars are about $100 per one.
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by skhan91 View Post
    Thanks for the explanation. PPI from Audi dealer didn't indicate any issues with DRC or control arm bushings but I will check if there is a recall for them for my car (I assume they would have already told me this during the PPI). During the next oil change I plan on getting them to look and see if it needs a carbon clean. Car seems to run fine, at least during the test drive. I pick it up later today.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    oh congratz! yea generally with only 38k you wont NEED a carbon clean and audi simply denies the fact that these cars have heavy carbon buildup so they will likely say that it needs no such thing. but if you get the carbon clean done you will notice it will free up a noticeable amount of power. if it has never had a carbon clean done ever, i would highly recommend one even if you have to pay for it yourself
    Dec 07 2009
    East Coast
    60k is still baby miles for this car. There're plenty of RS4s with well over 100k mark and are as healthy as they can be. RS4 engine is completely different than that of S4, much more stout and doesn't have same issues as BHFs. Do a PPI, service records and buy one, it's a joy.
    Forget the B8, keep the V8!
    Jan 15 2010
    Santa Barbara, CA
    Not at all. There really aren't that many RS4's left with less than that anyway.
    If the car is well-maintained, I wouldn't hesitate to get one with 60k miles.
    Senior Member Three Rings bigoltater's Avatar
    Jan 27 2015
    2013 Q7 S Line / Prestige, 2005.5 S4
    Bend,OR
    Quote Originally Posted by killintime View Post
    Hello out there...
    What say you?
    I bought a 2007 with 115k miles, runs like a champ, who ever owned it before took excellent care, high mileage don't scare me. But after owning 3 audi's and 4 bmw's in the past 15 years I will have to say by experience from 70k-100k miles they do drain your bank account.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    May 02 2007
    VA
    Thank you very much everyone. Unfortunately, someone else got her...this morning.
    I was going to make the 5 hour drive to get her on Wednesday.
    Guess I should have gave them a deposit. So, someone out there snagged a good one.
    I do see RS4s for sale with less miles...way less at times. However they want a fortune for it.
    Cya
    Oct 13 2014
    There is an RS4 for sale in the UK with 221,739 miles. I would say 60k is just getting broken in.
    http://www.autotrader.co.uk/classifi...01504283004806
    Jan 27 2015
    Bend,OR
    Quote Originally Posted by Eric F View Post
    So that's about $17,000 USD.
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Quote Originally Posted by bigoltater View Post
    Looking at that add, i'm wondering are Euro seats in the RS4 different then the ones in the US?
    http://pictures2.autotrader.co.uk/im...640&height=480
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by brad65ford View Post
    yes they are
    May 30 2005
    fl
    yes they are
    They look good! can we get them here in the states or are they something that is not stocked any more. Holy hell that aren't cheap its like a 1/4 the price of the car http://www.ebay.com/itm/Genuine-OEM-...1WZZ7b&vxp=mtr
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    unfortunately the only way to get em are to have em shipped from europe and they will likely cost something like $7-10k
    May 30 2005
    fl
    You aint joking wow
    https://www.bks-tuning.com/oem-euro-...ort-seats.html
    what i want to know is then why do the US rs4 have other seats? I'm assuming ares are from the S4's?
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    they are different from the S4. but still are recaros. apparantly the US seats are more comfy then euro ones but obviously the euro ones look better :s especially in red!!
    few things different in euro vs NA model: seats, steering wheel, front bumper, and i think wheels?
    euro also had a lower ride height option available too
    May 30 2005
    fl
    What that much differences! wow, i didn't know the bumper and ride height are different. Was is the different of the steering wheel and wheels?
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    the stock euro wheels come in 18" i think while we get 19. i could be wrong
    the euro steering wheel is flat bottom with aluminum trim and does not have the volume control buttons but instead hasthe S button on the steering wheel
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Cya
    thats too bad. if i was looking for an RS4 in the US, id look around in many states before making a decision. theres some gems out there, just gotta find em.
    if you were willing to come to canada to get one, theres one for sale with 50k miles and tbethe asking price is $35k CAD. which is ahout $25k USD. probably some room to haggle down closer to $23k ish
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Except in the UK where 19" was standard and 18" was the option.
    the euro steering wheel is flat bottom with aluminum trim and does not have the volume control buttons but instead has the S button on the steering wheel
    plus the trip computer controls are on the FBSW as well.
    Jan 14 2007
    Hampshire, U.K.
    Because AoA didn't want to pay the cost of getting US approvals for the bucket seats (as they are called this side of the pond), which as they are only fitted to the RS4 would be a siignificant cost per vehicle.
    Dec 07 2009
    East Coast
    You can get a set of these MUCH cheaper than 7k these days. That's double than what one could get these here after all expenses. Hardest part is finding a seller who wouldn't mind shipping to US and arranging shipping.
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Not only the seats are better, the brake are bigger. BTW, my car has 161K
    May 30 2005
    fl
    boy oh boy they really give us just a tease lol. Let we ever are going to get an avant again too :-(
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by d2a4 View Post
    didnt know about the brakes being bigger. which are they? i think they offered a ceramic option but didnt know they were bigger
    Senior Member Three Rings musasabi's Avatar
    Aug 11 2014
    Chicago, IL
    Yeah. The ceramics required the 19" rims due to 280mm rotors etc etc.
    2014 S4 | 6MT, Moonlight Blue, Black Optics, Sport Diff, Navi+, B&O
    2008 RS4 | Daytona Grey, Titanium, Exclusive
    2013 Jetta TDI | 6MT, Fender Audio, Sat Nav
    2003 Passat GLS | 5MT, APR 93 Tune, Koni FSD/Eibach Pro Kit, Magnaflow Muffler
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    380* ? cuz stock brembos in NA are 365 i believe
    Aug 11 2014
    Chicago, IL
    Yeah, you got me on that typo. =D
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by musasabi View Post
    >:) typo police haha
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    We have a number of customer cars (stock and supercharged) between 85k and 120k (and one that's in the 130k's). As long as you stay up with maintenance, the only common "faults" seem to be the knock sensors and the starters (and increasingly, the oil cooler lines, but due to the rust, it may be a salt belt thing). Just find a well maintained example and enjoy it.
    Feb 13 2004
    Quote Originally Posted by Sales@DriveAuto View Post
    Indeed, just replaced the stater. When I under the car, the oil pan is bone dry, not even a single oil wet spot.
    Nov 05 2015
    Westchester NY
    Drive just installed the Forge oil cooler kit for me this past week. Much less expensive than OEM lines and cooler.
    It was something the Audi PPI missed. I should've taken it to an Indy like Drive instead of the dealer for PPI -- they noticed it right away.
