Wow for that kind of coin, ship mine out from the east coast. If it was me, before I spent $10K on another S6, I'd drop $20K from an RS6 engine swap :-) But that's me, my s6 is a fun car and snowmobile (I've got another audi under warranty for getting to work).
I've learned the hard way you want the devil that you know in the C5 chassis. There are so many known issues on these that happen due to age or mileage that you need to be prepared.
I picked mine up off auction from a reputable seller at ~90K miles a few years back. In hind site it was a silly amount to pay to get everything running again and working, and this was likely a 'good' one with nothing 'major' and multiple PPI. If I bought another Audi of early 2000s vintage, I'd either get a no $$$ spared version from enthusiast moving on or one dirt cheap and expect tons of my time OR $$$ to get it how I want it. If you're paying someone else to do work for you (as I have to do more an more due to work), I'd say just go get a lease payment on a Cayman S or Focus RS for fun and call it a day.
Since I haven't written it down.. for grins I've done the following some typical maintenance, plus lot's of C5 fun from ~90K to ~108K in 3+ years
-Flexible Brake Lines (starting to rot)
-All control Arms front and rear (uppers, lowers, etc)
-Turn Signal Relay
-Timing Belt / Water pump (original @ 95K)
-Rear driveshaft gasket (leaking)
-Struts (I went coilovers and adjustable UCA however the originals were done @ ~90K)
-Front and Rear Strut Mounts (dry rot)
-All Vacuum Lines (CEL - leaks, poor idle)
-Air oil separator (The pancake / honker)
-Y Pipe (clogged)
-Coolant Temp Sensor
-Alternator
-Front Engine Torque Mount
-Front CV Joint/Axles
-Front Rotors (Vibration)
-Fuel Filter ( looked original)
-All 8 Spark Plugs, air filter, cabin, etc
-New Battery (shockingly was an audi OEM)
-Full fluid change to get baseline (Differentials, Gear oil, steering, coolant)
-Replace peeling soft touch controls on climate and door (not functional but a must do)
-Valve cover gaskets (oil leak)
-Clean out water drains (sunroof, battery tray)
-RNS-E / OEM Bluetooth ('needed' modernish electronics)
-RS6 OEM wheels and real performance tires (garbage all seasons on the OEM rims using in winter)
-Aero windshield wipers
To Be Done:
- Bose Speakers (just started buzzing)
- Replace antenna mount gasket starting to crack
- Replace air quality sensor
- Repair/Replace headlight level sensor
- Refinish/replace headlights
- Rear Interior Light repair (doesn't always come on, re-solder)
- Minor cluster fade in heat of summer
- New Rear cargo cover (plastic cracked)
- Rear hatch trim (triangle Cover broken and sunshade mounts)
To fail next- :-)
- Front Wheel Bearings (replacement ready)
- Plastic Coolant Pipe (buffkin replacement ready)
- Catalytic Converters ( 14+ years...)
- O2 Sensors
- N80 valve, SAI, and other emission garbage
- Cam Adjusters
- HP2 Caliper rebuild or 17z replacement
- Not least.. Triptronic failure
But damn that widebody avant is sexy
