Results 1 to 19 of 19
Thread: RS5 Cat Deletes
    Nov 19 2012
    Irvine, CA
    RS5 Cat Deletes
    Does anyone know where I can find some RS5 Cat deletes?
    Sound clips will be cool too :D
    Thank you :D
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Nov 10 2014
    Apex, NC
    are you doing it for performance or sound? because either way its not worth it
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    http://www.kline-innovation.com/exha...udi/rs5-2/rs5/
    The only true cat delete exhaust.
    Sit down before you look at the price!
    Jul 25 2011
    trying to shoot flames? lol
    Nov 19 2012
    Irvine, CA
    That K-Line Exhaust sounds sooo good!
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    I want nothing more than to shoot flames :-/
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Feb 27 2014
    Dubai
    Quote Originally Posted by chrissurfr View Post
    I know a few girls that can help you out Chris, it's nothing that two weeks on anti-biotics doesn't cure.
    Senior Member Three Rings rasetsu's Avatar
    Sep 24 2013
    2014 RS 5
    Frisco, TX, United States
    Quote Originally Posted by JamesRS5 View Post
    Haha!
    RS5 cats are all the way up against the exhaust manifolds next to the engine. I believe it would require engine to be lowered to install. Eliminating the front resonators which a lot of people mistake to be the cats would be a lot easier and cheaper.
    2014 RS 5 Sepang BLUE
    2017 Cayman S
    2018 Macan GTS
    Nov 19 2012
    Irvine, CA
    So Downpipes will be better? Im looking for a change of sounds.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
    Senior Member Three Rings AirmattRS5's Avatar
    Jun 05 2014
    Irvine
    what do you have against the environment and my future offsprings, bro?
    The name is Paul, not Matt // @rs_cinqo
    '14 Sepang Blue RS5 / Res-delete Sports Exhaust / Black Optics / Nav / Adaptive Cruise Control / KW H.A.S. / Forgestar F14 20x9.5 +22 offset / Huper Optik 30%
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    If you're looking for a little more sound, you would probably be better off replacing the stock resonator and mufflers with some quality straight-through ones. It will give you a big improvement over stock, without having to mess with your cars emissions equipment.
    Nov 19 2012
    Irvine, CA
    Quote Originally Posted by MagnaFlow View Post
    I replaced the stock resonators already. I dont want to touch the mufflers because i am afraid of messing up the drive select.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
    Veteran Member Four Rings scottykenneth's Avatar
    Dec 01 2006
    S .NJ
    Quote Originally Posted by zhclvn View Post
    Just buy a Capristo. Has the valves so you can keep drive select
    Instagram:ScottyKenneth
    ScottyKenneth's Build Thread
    PRESENT : White 2018 Porsche 911 GT3 ( manual) / 2018 Jeep Grand Cherokee Altitude
    PAST : 2018 White Carrera 911 GTS / 2018 GT Silver Carrera 911 GTS / 2016 Porsche Cayman GT4 / 2015 []RS5 / 2014 S5 / 2010 A5 SLINE / 2007 A4 SLINE / 2001 A4 /
    Aug 28 2015
    Illinois
    Quote Originally Posted by doug97gxe View Post
    Why wouldn't deleting the restrictive catalytic converters improve performance?
    A freer air intake with a header system with less restrictive catalytics further back or deleted altogether should definitely be an improvement.
    Prism Silver RS5
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by PedroRS5 View Post
    Well for one NA cars aren't really that restrictive u will see maybe 5hp .. Second it's illegal .. I don't know if you're in the US but it's a $10,000 fine if you get caught .. Maybe worth the risk for you at 5 hp ..
    Sent from my iPhone8s using Tapatalk
    Present:
    Aug 28 2015
    Illinois
    We don't get emissions tested out in the cornfields of Illinois, but it's definitely not worth it for a measly 5hp...however, the Kline headers are gorgeous!
    Prism Silver RS5
    Aug 28 2015
    Illinois
    Why only 5hp? With a good intake and exhaust, a set of headers would definitely increase the engine's efficiency and power.
    Prism Silver RS5
    Nov 10 2014
    Apex, NC
    only my assumption .. i was wrong on the assumption the eventuri intake would only make 10 hp .. it ended up making 20 .. so i could be wrong here as well.. but in a traditional sense.. it would only be 5 hp
    Present:
    Nov 19 2012
    Irvine, CA
    I want it louder. Maybe Capisto. Im considering my options.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
