Results 1 to 3 of 3
    Jan 30 2015
    SC
    Cracked single peeler from S4 19x8.5 ET43 - No Longer Available
    The wheel has a small crack on the lip and slowly leaks air until the tire seals the gap. It can probably be repaired but IMO this should be used as a test subject (for colors, etc.).
    Disclaimer: This wheel should NOT be used as is. It leaks air and could potentially fail.
    Asking $100 shipped OBO. This wheel is clean with no curb rash.
    List Date: 1/30/2016
    For more info, click here to view the original listing: Cracked single peeler from S4 19x8.5 ET43
    This item is no longer available.
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    I don't understand why you're trying to get money for a cracked wheel.
    Those are bad news. 90% of wheel repair places in the USA will not touch those.
    I've had one with similar defect and I trashed it. Not worth the hassle
    You cannot weld around the lip, at least not on the inside where the tire seals around.
    2007 Avus Silver Rs4
    Bone Stock
    Jan 30 2015
    SC
    Quote Originally Posted by Avus RS4 View Post
    I was unaware of that, I was just regurgitating information that I was told. If that's the case, I'll lower the price. You could still use the wheel as an experimental wheel so you don't ruin your actual wheels.
