Results 1 to 7 of 7
    Aug 05 2013
    Midwest
    ECU Serial Number for Automatic/Manual
    Hey guys,
    I have to replace the ECU in my 1999 A4 2.8 and I was wondering how to tell by the serial number if the ECU is automatic or manual. The sticker with the serial number is removed from my ecu.
    I am searching on Ebay and I want to make sure so I don't have to reprogram it. Thanks
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    You need to look for an ecu that is already coded for an automatic then. Pretty sure the ECU's are the same part number but I could be wrong.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Aug 05 2013
    Midwest
    Quote Originally Posted by Wrath And Tears View Post
    It looks like there is :
    4D0 907 551 A
    4D0 907 551 AH
    3B0 907 551 BQ
    Apr 03 2014
    17 GTI Sport
    Call the dealer with your vin and ask for the part number for the ecu. Then you will know for sure.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    What is the number on your current ECU?
    I might have a spare laying around.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Apr 03 2014
    17 GTI Sport
    The number on his current ECU (sticker) got removed so he doesn't know unfortunately.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Correct, a manual or automatic ecu can easily be coded with vagcom to work with either transmission.
