Results 1 to 8 of 8
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Downpipe Questions
    Search has failed to unconfuse me...
    I have the AWE cat back. Later I had an hfc installed but with too many cel issues and not wanting to deal with it all, I went back to stock.
    But I loved the sound, and would like to get a little of that back so considering a downpipe.
    1. Is install easier than HFC? I couldn't manage the HFC myself but would like to attempt the DP install, especially if it's done just from underneath the car. Anyone install a DP?
    2. Does it matter which one I get? I know they don't add power, just some sound. So would something like the CTS dp be basically the same as the AWE dp?
    TIA!
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I'm not certain on the degree of difficulty for install. I'd imagine it should be considerably easier than the HFC but I've never personally installed one.
    The AWE DP is resonated, whereas the CTS DP is not. That is the only difference between the two.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    The tougher part of the install is the turbo nuts and the spring bracket. A downpipe is still going to have those same connections and won't do more to avoid cel than an HFC would, if the DP had a low cell cat.
    Did you have a spacer on the HFC second O2 sensor?
    Stay classy.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by blbroo View Post
    Both of these DP's are the lower portion only (without cats) - mounting up to the OEM cat.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by adamazing View Post
    Oh. That's pretty easy then. Just three nuts and a slip joint.
    Stay classy.
    Jan 13 2006
    Houston
    Ok cool, so I can just put the car up on ramps and go at it from there? Nuts easy to reach?
    Thanks for pointing out the non-res... missed that.
    I want more grunt when on the gas, but don't want any drone when cruising. The awe cat back with the HFC was great, still no drone but sounded awesome.
    Established Member Two Rings RW12's Avatar
    Dec 28 2015
    1997 Safari van, SV650 Superbike, YZ85 supermoto
    Vancouver
    Sorry to bump an old thread, but on the CTS website they say "substantial power gains" with their downpipe. That's BS right?
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    I have a CTS downpipe. I would not buy it again, given the option. It didn't fit correctly when I first got it. It was contacting the transmission. They wouldn't refund it because I had installed it. I sent it back to be fixed. It was re-welded, but still didn't fit properly. I ended up having a local shop weld it another time. It fits now, but looks like crap from being cut and welded so many times. No drone, but it wasn't worth the headache. No power gains, substantial or otherwise.
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
