Results 1 to 11 of 11
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    yikes this thing is running terrible.
    so i got a P2015 the intake manifold code. my car isnt under warranty anymore. im at like 99xxx miles. I was told that I can get the intake manifold replaced for free by the dealer. is this true ?? i also have a misfire at idle. but my plugs and coil packs are brand new. would this cause a misfire ??
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    May 22 2013
    Southern ME
    Have you ever done a carbon cleaning?
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    try a new PCV valve. make sure you get the correct part no. (depends on whether your had oil consumption stg. 1 done).
    Sep 26 2015
    Syracuse NY
    had carbon cleaning done 3K miles ago
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I have a feeling your intake manifold gave out and the flappers failed. Has your intake manifold been replaced previously? You can DIY and source a new manifold ~$250. The dealer will charge in excess of $1,200 when I got a quote (it was done under warranty and I was told about the stupid flappers that sometimes fail, wanted to know how much I would have to pay if they failed again...).
    My 2009 A4 Prem+ Build thread
    Sep 26 2015
    Syracuse NY
    I do not know if it has been done before, How can I find out ??
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    My car just had this a month ago. 31k miles on it. Dealer replaced the manifold.
    Pedal Responce first responder.
    Oct 10 2012
    Zionsville and Saint John IN
    Follow the DIY and save several hundred dollars. If you open your hood and have the car running... Look at the rear of the intake manifold and I'm sure you'll hear a loud vacuum leak. I don't understand why dealers charge so much when it's really a two hour job.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by richardm0025 View Post
    The part is pretty pricey.
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    $213 and free shipping at ECS for a new manifold and about an hour and a half long job to swap it out. You can clean your valves while you're in there and do it all for a fraction of what it would cost to have a dealer or shop do it.
    Follow the DIY on here and you'll be fine.
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
    Oct 10 2012
    Quote Originally Posted by 4ringnut View Post
    I think I paid 225$ at the dealer for the part. Still saved a lot doing it myself.
    The DIY threads on here are awesome. I never dreamed of replacing a turbo on this car but having a guide really makes the process easier. Cheers to audizine!
