NEW Snow Performance Stage 3 Boost Cooler (Boost/Direct Injection) 320
I have a brand new Snow Performance Stage 3 Boost Cooler (Boost/Direct Injection) 320 with Solenoid Upgrade. Included in the kit is below. I also have a Male and Female 3 pin vag connector to make a jumper harness so no splicing wires to tap into the High pressure 0v to 5v sensor.
Asking $800 shipped. The solenoid upgrade is a $60 upgrade.
Kit includes:
300 PSI UHO (Ultra High Output) Pump
3 Qt Reservoir
All Tubing Necessary for Installation
10' ? Inch High Temp Nylon Tubing
18" High pressure Boost Line
Terminated Digital Variable Mapping Controller
Terminated Plug&Play Wire Harness
Power Solenoid Upgrade
Level Switch Upgrade
2 Nozzle Holder/Check Valve Combo
3 Hyper-Sonic? Nozzles
Snow Performance Running S Decal
Required Hardware Needed For Installation
Comprehensive Instructions to Install on Direct Injected/EcoBoost Vehicle
Solenoid Upgrade
List Date: 1/29/2016
For more info, click here to view the original listing: NEW Snow Performance Stage 3 Boost Cooler (Boost/Direct Injection) 320
This item is no longer available.
