Results 1 to 9 of 9
    Dec 11 2015
    PA
    Injectors ; ECU for APR Stage 1+ or Injectors; test pipe; APR Stage 2 ECU
    I'm considering bumping up the performance of the b6. I'm either going to go stage 1+ or stage 2. I'm looking for the injectors, ecu and/or test pipe for Stage 1+ or 2.
    Let me know what you have!
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    If you get an ECU you have to do IMMO defeat on it. You are better off paying the $500 for the tune and just find TT injectors. Ebay test pipes work but you will not pass PA emissions with it.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Senior Member Two Rings mpower's Avatar
    Feb 02 2008
    01.5 Nogaro B5S4, 2012 B8S4 Glacier Prestige, 09 Q7 S-line TDI
    Chicago
    You can, but don't have to do immo defeat on used ECU.. Read PINs and adapt ECU in the car no problem with VCDS. There is no such thing as immo defeat in cluster. Immo defeat is only done in engine ECU.
    Dec 11 2015
    PA
    Okay thanks for the tips.. I thought the ECU was plug n play.
    I can have the tuner tune out the 02 sensor for the test pipe, correct?
    Feb 05 2014
    Quote Originally Posted by iksnoved25 View Post
    Will not pass readiness so you will most likely fail. States have been cracking down on it which is why I don't even bother doing it on my cars anymore lol.
    - - - Updated - - -
    Quote Originally Posted by mpower View Post
    Thanks for the info but not sure this is something that is easy to most.
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    I have maestro 7 avble, test pipe, injectors and more
    Just saying
    Nov 10 2015
    Sudbury, ON
    I got 410cc OEM Bosch injectors for sale.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Veteran Member Three Rings larry_fopps's Avatar
    Jul 29 2014
    MK3 2.9L Vr6 WIP
    Sayreville NJ
    I have everything you are looking for from a partout. APR 1+ ECU with the immobilizer already defeated and TT225 injectors. $600 Shipped. I also have a test pipe, looking for an additional $75 shipped on that.
    Veteran Member Three Rings quattro guy's Avatar
    Nov 30 2014
    06 audi a4 quattro 2.0 6sp
    rockford il
    I got the bosch 386cc injectors with like 4k miles
    02 audi a4 Quattro 1.8 6sp, milltek exhaust, Motoza e85tune,f21 @26psi,stage 2 ra4 clutch, hyperboost diverter valve, 18z brakes, rear s4 brakes, TR11 FMIC, je pistons,ie rods 2.0 coil convertion kit (best 1/4mile time on stock engine at 21psi 13.4 @101mph)
    06 audi a4 quattro 2.0 6sp, gfb diverter valve, 2.5" test pipe, apr stage 2, r8 coil packs, s4 front brake
    05.5 a4 2.0tq 6sp, r8 coils, motoza e85 tune. S4 front brakes.
