Results 1 to 6 of 6
    Active Member Two Rings manniakk's Avatar
    Dec 09 2014
    Sofia
    Tyre pressure monitoring system 7K7/7K8
    hello guys, im about to retrofit basic tpms to a preface a6c6, I need some information about what is different from high, I know 7k7/7k8 is widely used in the states so there will be a lot of info. I need to know:
    Does the basic system show the tyre pressure in the MMI or it just controls the light on the dashboard?
    Any help is apreciated!
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    The basic system only controls the light on the dashboard. I don't think the C6 A6 got the MMI type pressure system where you could view the pressures. The early versions used regular sensors that only told you when you were below 35PSI and the facelift used the ABS sensor to detect a difference in rotation from that tire to determine if you had low pressure in a tire.
    Personally i would go just without it. It adds more maintenance costs (not much but 200-500$ every couple years) and I can't see it being easy to retrofit.
    Dec 09 2014
    Sofia
    thank you for your reply. I managed to dig some info - Its being referenced as "TPMS Systems without Wheel Position Recognition". It seems you are able to access all the sensors information from VCDS but i dont know if its possible to assign each sensor a wheel position. I`m retrofiting APS advanced and i have to disassemble the car for the cables and i thought its a good idea to add tpms basic, because i dont want to run senders to each fender. And i found the module and antenna for about $20, The wiring is another $20...
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Quote Originally Posted by manniakk View Post
    Where is Sophia out of curiosity?
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Wow, no kidding haha
    2005 BMW K1200S
