Results 1 to 6 of 6
Thread: ELSA, ETKA
    Mar 05 2013
    CA
    ELSA, ETKA
    How do you get it to run on 10?
    Dec 28 2015
    Wake Forest, NC
    I've got mine running in virtualbox as a VM. I think that is running win 7, but... It might be xp.
    Sent from my XT1585 using Tapatalk
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Quote Originally Posted by CaptainJohn View Post
    Same thing here, running Win 7 but all my factory manuals run in XP Mode using Windows Virtual PC.
    Sep 15 2012
    Kingsland, GA
    I installed Elsa on 10 the same way I did on 7. Works just fine. No virtualbox, just a straight install like any other program.
    Jan 06 2009
    Quote Originally Posted by fast377 View Post
    This, but ETKA instead of ELSA.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Aug 26 2005
    After installing the program software, open the folder and select the executable, then right click on Properties, Then select Compatibility Mode for Windows 7, and also select Run as Administrator.
    If the program installation software will not run, then the Compatibility Mode for Win 7 needs to be applied to the installation executable, then the program installation software run again.
    Before installing the software, make sure the system has the required supporting packages installed. For example, .Net and C++ with the right versions. Check the installation prerequisites.
    Vorsprung durch Technik
