So about a year ago, my heated seat died. I thought it was no biggie; I bought another seat and took out the heated element and put it in the car. That didn't fix anything it still didn't work.
Then about 8 months ago, the front window defroster would work intermittently. I scanned the car and it was the servo.
About a month ago I pulled my motor to rebuild it. After driving about 500 miles I noticed that the red light on the ECON button stays on at all times. So I scan for codes and I find these -
7 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
01810 - Actuating Motor for Temperature Flap; Right (V159)
00716 - Air recirculation Flap Positioning Motor (V113)
01232 - A/C Compressor Regulator Valve (N280)
29-10 - Short to Ground - Intermittent
00825 - Drivers Seat Heating Element (Z6)
31-10 - Open or Short to Ground - Intermittent
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
So that's basically all of the servos/motors for the air system and two for the AC system.
My question is, is this really 5 motors and the AC condenser going bad? Or is this something else that is going bad like the climatronic or a control module? Thanks in advance.
