Results 1 to 19 of 19
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    Wheel fitment help!
    does anyone know if an 18 Inch ET48 will fit on a B8 S4 (ET43) ? ... will this rub?
    sorry in advance, yes I did use search but it im not scrolling through 50 pages of nonsense, In a rush as i need to find a set for tomorrow as I am picking up my new ( new to me ) S4 !! figuring out my winter wheel setup.
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by TomPaul10 View Post
    It would depend on the width.
    Anything narrower than a 10" wheel with that offset will clear the front suspension, and that offset in pretty much any width would clear the fender. The stock 18x8" wheels are ET47 for reference, and have plenty of room on both sides.
    Maybe you think the fitment thread is nonsense, but the answer is there, and if you can't find it, it's probably the best place to ask this question.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Stage 2 Banner Advertiser Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    I just test fit an 18x9.5 et45 on my car. Extremely close on the inner suspension. I wouldn't go wider than that with a 45 offset.
    Sent from my VS986 using Tapatalk
    AKA: jbullin2
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by jbullin2 View Post
    Was that the RPF1? If so, how was the brake clearance?
    You should have another 3-4mm of clearance on the inside, but yeah, it's getting close.
    Dec 21 2014
    Milwaukee
    It was the rpf1s! I stupidly didn't test the rear fitment although maybe you can comment on the relatice suspension clearance between the front and rear.
    There was ample room for the stock brakes. Now to get a set drilled to 5x112...
    AKA: jbullin2
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    The rear should be fine. Let us know how it works out once they are redrilled. Looks good so far.
    Dec 21 2014
    Milwaukee
    Thanks for the reassurance!! I'll have everything together by the end of next week. I'll be starting with 235/40/18 Nokian Hakapelliitas for winter autocross. Then switching to 275/35/18 RE-71r's for summer autox. That will be the real test of clearance.
    Will post pics as soon as I get them on!
    AKA: jbullin2
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Nice. Looking forward to seeing the RE-71's. That will definitely be aggressive on both sides.
    Dec 21 2014
    Milwaukee
    Well, I can confirm that the fronts fit great, and I should have checked rear brake clearance...oh well, at least they're lighter now!!
    I'm going to grind the caliper down a bit. Don't want to remove more material from the wheels than necessary; and certainly don't want to risk lugs coming loose!
    On the plus side, they sit quite far in from the fenders, which will be perfect for getting some 275s crammed in there. These pics are with 235/40/18 Nokian Hakkapeliittas. RE-71s to come in a month or so.
    And the redrill is hardly noticeable:
    Dec 21 2014
    Milwaukee
    Teaser with the 275s. Test fitting tomorrow without control arms dropped on PSS10s. Control arms going on Sunday.
    AKA: jbullin2
    Jan 09 2008
    Winnipeg
    So that's a275/30r19? And a 9.5" wheel?
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by eurotic View Post
    275 35 18 on 18x9.5 et45 RPF1 redrilled to 5x112.
    AKA: jbullin2
    Jan 09 2008
    Winnipeg
    Wheel fitment help!
    Looks like just a standard load tire too and not XL. I'm interested to see how that holds up at autocross. With such a heavy car I try to get the stiffest side walked tires I can. I think Bridgestone have a reputation for heavy tires because the sidewall construction. It probably holds true for their SL tires too.
    I have a set of RE-11's going on in a few months.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Nice. I'm also interested in how the RE-71's hold up. Are you only going to use them at the track?
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by jran76 View Post
    Yes, these will be autocross and track only. I ran RE71s last year in 255 35 19. They held up amazing. I got well over 130 autocross runs and a huge lapping weekend out of them (100 mins of track time), plus about 500 miles of road driving when I was too lazy to switch back after a couple events. There was literally nothing left of them at the end.
    AKA: jbullin2
    Dec 21 2014
    Milwaukee
    Tried them on today without SPC control arms. Slight rubbing in the back on the right side on the fender liner. May lift it up a touch or try to jam the fender liner in. Front rubs only with the wheels turned quite a bit with the suspension loaded up.
    Rear outer fitment
    Rear inner fitment:
    Front outer fitment:
    Front inner fitment:
    Compared to 19x9.5et40 AG M510 with 255 35 19 tires
    AKA: jbullin2
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Cool. Thanks for the pics and details on that setup.
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    Jbullin - Can you share where in the front you are rubbing when the wheels are turned? Is it on the fender lip or fender clip? Have you done any fender work? Specifically, did you remove the front fender clips and/or do any rolling? Any issue with the rear fender nub, where it meets the bumper? Can you share your alignment specs?
    I just ordered some 19x9.5 ET45 wheels with 275/35/19 tires, and I'm trying to learn what to prepare for. Thanks!
    Dec 21 2014
    Milwaukee
    Quote Originally Posted by Danny2323 View Post
    The rubbing is where the fender clip used to be. RE-71s run wide, so I was rubbing all last racing season on the stock Rotors with 255/35/19s on. When they were new, I was rubbing on the fender screw. They rubbed away all the plastic around the screw, so I removed it. It still rubbed on the inner fender in that screw area (towards the rear of the arch) for a little while and eventually subsided as the tires wore down.
    A quick update:
    I raised the rear up a quarter inch (was set ALL the way down on the PSS10s) and adjusted the camber as far in as the cam would let me, and there is now ZERO rubbing in the rear. I installed SPC control arms in the front and turned each turnbuckle exactly 3 turns shorter than stock length (so 6 threads total since the turnbuckle adjusts each end at the same time). I now have ZERO rubbing in the front. I haven't gotten a formal alignment yet, but I measured with an inclinometer a little over 3° all around. I will report back what it actually was when I take it in for alignment.
    The results? This setup is fantastic! I couldn't be happier with them!! There is so much more grip than the old 255s, and the PSS10s are a joy! I absolutely annihilated the competition at the "Winter" Autocross held at Road America a couple weekends ago. I went out with the PSS10s set all the way to 10, and after skipping over some of the undulations in the pavement transitions, turned them down to 7 for the afternoon session and had perfect grip the whole time.
    Youtube Video here:
    https://www.youtube.com/watch?v=GvYNHaTfg48
    Results here (the 2nd place Subaru Impreza time was due to a timing error, his other laps were 10s slower):
    http://fvscc.com/results/2016_Winter/event3ax_raw.htm
    http://fvscc.com/results/2016_Winter/event3ss_raw.htm
