Results 1 to 6 of 6
    Mar 01 2007
    SLC
    AWE Touring exhaust for 3.0T - any fitment issues?
    I spoke to a local shop and they stated that the have had fitment issues with AWE exhausts but he has not done one for the Q5. He is very pro Milltek but I don't want to do the quad tip and SQ5 valence. For those that have done the AWE, did you have any fitment issues? Thanks for any feedback. RIght now, the plan is to do exhaust and H&R springs.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    nope no issues, just takes a few minutes to get the tips aligned right.
    w/ downpipes
    fyi- milltek exhaust was designed for 3.0TDI engine of euro SQ5's
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Established Member Two Rings candyblancogti's Avatar
    Oct 22 2015
    2006 Mk5 GTI
    Denver, Colorado
    I had slight fitment issues with my AWE non res downpipe exhaust. The entire system kept shifting to the right and rubbing on the rear valance.
    Just fixed it the other day. Had to saw off a bit of the pipe on the passenger side to help it stay center. So far it hasn't shifted. Overall it's just a slight annoyance, as the sound is totally worth the time to adjust the clamps every once in a while. Just my 2¢
    Aug 06 2015
    Chicago
    AWE has a lot of adjustment but with patience can be adjusted just fine.
    Mar 01 2007
    SLC
    Thanks guys!
    ‘19 RS5 SB
    '19 Q7 3.0T
    ‘18 Mini JCW
    '12 Mini Cooper S
    ‘98 4Runner
    Mar 13 2013
    Chicago Western burbs, Il
    I had a shop install that does lots of Audi's exhausts and the tech did a number of adjustments while tightened up components and it fit like a glove. It wasn't just an install and tighten once. The down pipes were a little tight but even there it all went together and its been rattle / rub free since it went on early last summer. Just excellent sounds.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
