Results 1 to 6 of 6
    Feb 26 2015
    Sweden/Malmo
    problem with the AC fan
    hello everyone,
    i have a problem with fan to my AC, i took it to a authorised workshop that works with VAG cars, they did a
    troubleshooting and said that Audi Blower Motor Resistor (8K0820521B) was bad or that the fan had been stuck, they where not sure.
    so i bought the part and replaced it my self real easy job, but the problem is still there, while i was replacing the resistor i connected 12v directly to the fan and it worked,
    i have check all the FUSE that have/has AC on them but they all good? some help
    Audi A4 2.0 TDI 2009 EU (sweden)
    Code:
    Address 08: Auto HVAC (J255)       Labels: Redir Fail!
       Part No SW: 8T1 820 043 P    HW: 8T1 820 043 P
       Component: KLIMA 1 ZONE  H05 0120
       Revision: A1000000    Serial number: 0115.03.080520
       Coding: 34000000
       Shop #: WSC 02399 823 56573
       VCID: 3E6A2EDBF0774CF22D0C78D-806A
    1 Fault Found:
    01844 - Control Module for Fresh Air Blower (J126)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 11
                        Reset counter: 159
                        Mileage: 166918 km
                        Time Indication: 0
                        Date: 2016.01.19
                        Time: 23:25:30
                 Freeze Frame:
                        Temperature: 4.0°C
                        Speed: 0.0 km/h
                        Load: 100.0 %
                        Load: 0.0 %
    Jun 26 2009
    Bremerton WA
    I had an issue where my fan had stopped blowing and it gave errors for fan or controller. The module mounted on the fan has large power wires feeding it and then the connection that goes to the fan motor itself. You can slide meter leads into the back of the plugs fairly easily to check voltage. Two large wires (power and ground) feed the module. Verify those have 12 volts. The side going to the motor will usually read between 3 to 12 volts depending on the fan speed setting. My issue was the motor brush dust had accumulated and one of the brushes wasn't making good contact with the armature. With the motor connector disconnected I would get a variance in ohms across the motor terminals when I moved the wires around. I removed the fan motor and removed it from the housing and flushed it with isopropyl alcohol and some contact cleaner. I cleaned the armature with a pencil erasure and it then read a steady 8 ohms (if I recall correctly). Reassembled and has worked great since. Also a good time to put a drop of machine oil on the bearings while there. The amount of black dust that flushed out of the motor was impressive.
    VMR 710's, APR software, Eurocode HFC
    Feb 26 2015
    Sweden/Malmo
    bump?
    Feb 24 2013
    CA
    http://wiki.ross-tech.com/wiki/index.php/01844
    - - - Updated - - -
    Ill keep looking tho
    Feb 26 2015
    Sweden/Malmo
    Quote Originally Posted by Slick_B8 View Post
    - - - Updated - - -
    any luck
    Established Member Two Rings valida4's Avatar
    Mar 03 2010
    New York, NY
    I had a similar issue as yours where the fan would start then stop intermittently but I replaced the fan only, not the resistor and it worked fine afterwards. I believe the control module is located on the fan housing and comes with a new fan and is separate from the resistor. I had the following error codes:
    Code:
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01161120090670
       Coding: 64102000
       Shop #: WSC 02391 823 56573
       VCID: 8004025EEC59951C
    2 Faults Found
    01273 - Fresh Air Blower (V2)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 131
                        Reset counter: 18
                        Mileage: 60040 km
                        Time Indication: 0
                        Date: 2015.09.23
                        Time: 08:54:55
                 Freeze Frame:
                        Temperature: 20.0∞C
                        Speed: 0.0 km/h
                        Voltage: 0.50 V
                        Current: 0.000 A
                        Voltage: 12.30 V
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 3
                        Fault Frequency: 33
                        Reset counter: 58
                        Mileage: 61372 km
                        Time Indication: 0
                        Date: 2015.11.13
                        Time: 18:50:46
                 Freeze Frame:
                        Temperature: 12.0∞C
    2010 Phantom Black Pearl A4 2.0 6MT :: Premium+ :: Nav :: Sports Package :: H&R Spacers :: S-Line Stone Guards :: APR Stage 2+ :: Podi :: aFe
