Results 1 to 2 of 2
    Dec 24 2010
    2001 A4 4.2 v8 swap, MR2 Turbo, CBR1000rr
    Columbus, Ohio
    what flywheel bolts? (4.2 v8 swap question)
    Hey guys, i am getting to the final stages of motor prep for my 4.2 v8 swap but had one question. i bought a SMF conversion 2.8 30v flywheel from clutch master and it came with flywheel bolts, but they are too short to thread sufficiently into the crank.. what bolts are you guys using? thanks for help!
    Nov 03 2011
    All Over!
    @ Spinning, the stock DM bolts are M10x1x19.5.
    What will work for your application will depend on how thick the boss of your flywheel is, what clutch friction disk you intend to use and whether the holes are countersunk or not.
    Please measure the boss thickness, so through one of the bolt holes. A picture of the said flywheel and clutch disk would help too.
    I would hate to advise you based upon MY setup, and you end up with bolts that are too long or too short.
    1986 Type 85 Audi 90 quattro
