Results 1 to 14 of 14
    Active Member One Ring Finky's Avatar
    Dec 21 2015
    2013 RS5, 2015 Ford Ranger
    Sydney, Australia
    RS5 / Keeping the drive select on Individual!
    Hey guys,
    Wondering if the is a way to keep the cars drive select to stay on a certain mode when turning the car on and off.. It's really annoying now Iv done the exhaust on my car and it is always changing to the shit mode haha 😂
    Cheers
    2013 RS5 | Suzuka Grey | Sports exhaust with mid X-pipe | Dynamic Sports package 2
    Veteran Member Four Rings LimaSierra's Avatar
    Apr 26 2013
    2025 Infiniti QX 80 Autograph, 2024 Chevy Tahoe RST
    KIAH
    Quote Originally Posted by Finky View Post
    Hey guys,
    Cheers
    Mine stayed in Indiv mode all the time (or the last mode I had it in). However prior to switching out my exhaust, I still had to put the car in "S" mode. No matter what setting you have it on, I think the RS defaults to "D" mode. Even if you have your settings set to dynamic for the exhaust mode (under individual), the flaps are still closed up every time.
    Which is precisely why I got a valveless exhaust! Was pretty loud no matter what mode I was in. Didn't wanna drive it in dynamic/sport mode just to hear the exhaust. I think there are some other ways of keeping the valves always open (in the trunk area) with the stock sports exhaust , but didn't wanna mess around with that.
    --Nate
    LimaSierraPhotography.com
    2014 Panther Black RS 5: Pics | Build
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    The only part of Dymanic mode that isn't in place when I start my car is the transmission. It will always default to D instead of S, but that doesn't make a difference to me since I drive in Manual mode all the time anyway. My exhaust still farts when I shift. This is on a 2013 S5, which I've been led to believe behaves similarly to the RS.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Four Rings jkownz's Avatar
    Jun 15 2011
    2015 RS 5
    Have a 15 and even if I put it on individual with valves always open. Once car is shut off and locked, once I start the car individual is highlighted but not selected. This goes for any setting I previously left it on. Only work around besides getting a valve less exhaust is go inside the trunk and disconnect the vacuum hose for the valves to always be on. Down side is you will see a pop up stating a issue. Not sure if there is any vcds to disable that.
    Sent from my SM-N920V using Tapatalk
    MODS 2015 Audi RS5 / Custom Made Headlights / Full Xpel PPF / Tinted / Blackvue DR650G / Eventuri Intake / BLK 501GTR'S 20X10.5's All around / Storage Bins / Euro Folding Mirrors / Capristo Exhaust / A.W.E Non-Res Downpipe / CF Engine Cover / 034 Transmission Mount Insert / Apikol Rear Differential Mount Insert / 034 Rear Diff Carrier Mounts / Euro Tail Lights + Sweep Module / L.E.D Interior Lighting / Airlfit 3H Bag Suspension /
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    Quote Originally Posted by jkownz View Post
    If you just disconnect the vacuum lines, there's no popup that you speak of. If you don't mind your valves being open 100% of the time, just do that. Previously when I just had the stock sports exhaust, I disconnected mine as soon as I found out about it. However when I got the Capristo installed, I plugged it back up and enjoy the quiet mode in the early mornings.
    Jul 17 2015
    Colorado
    Quote Originally Posted by PEM View Post
    ...but that's the best time to be loud for your neighbors!
    IG: @MrHazeMyth
    Account Terminated Four Rings
    Sep 13 2014
    New York
    In my cold start , my valves are open on my Capristo. I'm always in Individual and exhaust is set to Auto.
    Veteran Member Four Rings iBleedOrange's Avatar
    Oct 31 2012
    The one workaround that I have been using to get the valves to stay open during a cold is turn the car on but in accessory mode first. From there I will cycled through the drive select until it lands on dynamic mode again (even if my last mode prior to shutting off was dynamic mode) and then start the engine. There you will have your lovely cold starts with the valves open. I would imagine the same will work for individual mode if you have your exhaust setting in dynamic.
    Jun 15 2011
    2015 RS 5
    thats actually good to know. I assume it is the vacuum tube you disconnect. Not the wiring.
    Senior Member Three Rings AirmattRS5's Avatar
    Jun 05 2014
    Irvine
    that is correct. Leave the wiring and the plug the way it is, just disconnect the tube on one end and seal the opening with a small cap or just tape it up.
    Active Member Two Rings KaosuSoruja's Avatar
    Nov 17 2015
    Ontario
    Quote Originally Posted by AirmattRS5 View Post
    Just got my '14 S5, I cant seem to find a thread on doing this. Would anyone mind sharing on how to do this? I'd like to see the difference! thanks!
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Hey guys,
    Cheers
    This default to regular D mode when you start has to be to do with the official fuel consumption numbers. To get those they need all the planets aligned and getting to D7 by 30mph is one of the bigger planets.
    The flaps will be open for a second as the vacuum builds up to close them, but as many here do as the starting ritual - tap it down into S and push right into M, I don't even notice I'm doing it.
    Dec 21 2015
    Sydney, Australia
    Haha yeah right, so there isn't really a way to do it without changing mufflers.. I just really like the capability to have it sound off its head then go to zero noise when cruising home late night when it's just chill out and listen to some tunes haha. That Bose does a good job! 👍
    Cheers guys
    Nov 03 2015
    London Ontario Canada
    in individual mode with the open valves setting , after turning it off and then starting up again, the valves are closed even though it is still in individual. however, if you cycle through the drive select once and get back to individual, the valves open again as originally programmed
